wax pros..i need your input.
i have a generic electric buffer that i use on my car with good results. my question is: should i upgrade the buffer and buy a variable buffer? will an increase in speed yield more? my car is mil silver, although i cannot get a shine like black cars i still like the reflectiveness.
I think the Porter-Cable 4228/4336 is just about the best all around device on the market. I've got one that has seen heavy use for 10 years now and it shws no signs of age. This device makes detailing 10 times faster than manual. Most cheap generic buffers are not very useful. The variety of pads is limited and the power they bring to bear is also very limited.
There is no comparison.
The PC can be had for around $100 at Lowes.
Got to agree about the Porter Cable. Read tons of reviews at autopia.org and became sold on the PC. There are some amazing before and after pics there.
I purchased mine from Amazon.com last week. Now I have to buy the correct pads.
what pads do you think is good? what speed should i use and do i just go over and over again until is shines? can i actually burn the paint?
When using a polish like Meguiar's #80 or #83 apply a ring of polish to the pad and put it on the paint. Move it around gently to spread the polish in a 2' x2' area then turn on the PC to about 3. Slowly move over the area until the polish is evenly distributed then raise the speed to around 5. Don't go higher than 5. You cannot burn the paint with the PC polisher. Continue covering the area until the polish turns clear and looks just wet. Wipe off any residue with a microfiber and examine the area. If you still see some swirls repeat this again.
When applying a wax, load the pad with a ring and apply just like the polish but keep the speed at 3. It is not necessary to work the wax in. The goal is to spread it evenly across the panel.
Don't mix products with the same pad. If you change product, change your pad.
wow man. i cant believe it. ive been doing the old karate kid thing. wax on and wax off. so basically youre saying that i can use the same pad for the same product and just use the different speed until the product is clear? just wanna make sure that im doing this right.
and this http://www.autopia-carcare.com/mepovi.html
will answer most of your questions.
Basically the polishes I have suggested contain diminishing abrasives. They break down from the heat generated while polishing. As they break down they get finer and finer and eventually you are left with the oils which are clear.
are all porter cable polisher/sander the same?
andyvn579
Automotive Care & Detailing
05-23-09 10:33 AM
