LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
transmission fluid change
Old 08-04-04, 01:11 PM
roberttran
roberttran's Avatar
Default transmission fluid change
Hey,
I looked over the transmission section of the repair manual and it doesnt have the procedure for changing the AT fluid. Where is the fill and drain plug?
Thanks,
Robert
Old 08-04-04, 02:38 PM
dougjohn
dougjohn's Avatar
If you have the Factory Service Manual, check the Scheduled Maintenance section.
Can't tell you exactly where the drain plug is on the 470. The fill (at least with the 450) is via the tranny fluid dip stick tube.
Old 08-06-04, 06:45 PM
RPH74
RPH74's Avatar
You fill the AT fluid via the fill tube. I don't have any pics of the drain plug, but it is fairly obvious when you look under the car. The transmission pan is rearward of the oil pan, if that helps.
tgh2
05-29-17 12:09 PM
racerboi07
04-15-17 07:43 PM
Neil64
09-24-10 09:30 AM
Bobk528
RX - 1st Gen (1999-2003)
16
09-26-05 07:34 PM
lowlowlex
03-03-04 10:14 PM
Quick Reply: transmission fluid change
