View Single Post
Old 05-09-04, 05:37 PM   #8
Deanski
Trader Score: (0)
Default Zaino Dry Time
When I use Zaino, I wait long enough to then test it with the "finger" test. If you run a finger over the Z2 and the area from the finger is dry and shiny, it's time to take it off. If it's dull or wet, wait some more.
You are better off with ZFX. Not only does it cut down on dry time, but it seems to help bond better to a finish and cross-link faster. It also helps when applying more than one coat.
Hey, enjoy the Zaino! If you get streaks when removing, DO NOT use Z6 to try to remove them. Get your Z7 wash product and mix up 1/2 cap to 12 oz of distilled water and put it in a spray bottle. Use the mix of Z7/water to remove streaks. If you use Z6, it can just "move" the Z2 around and in some cases will end up not on the finish, but on your MF towel.
If you do not like the "plastic" look as some call it, wait at least 24 hours B4 you top it with a high quality pure carnuba. It deepens the look.
Regards,
Deanski
__________________
DR. SHINE
'03 SC430 Absolutly Red brought to you by Zaino! MY SC430
Deanski is offline   Reply With Quote
