Injector Maintenance Required
Old 08-17-14, 10:53 PM
Mesh704
Mesh704's Avatar
Default Injector Maintenance Required
https://i.imgur.com/MSVfU1i.jpg
Is there anyway to remove this !!?? I just got it today when I start my car in the morning !!
I heard there is a couple steps that u do to remove this !!
Old 08-17-14, 11:01 PM
faisal11ir
faisal11ir's Avatar
Strange at 10k km...... which petrol do you use?
Old 08-17-14, 11:23 PM
Mesh704
Mesh704's Avatar
95 ? But I've seen most new Lexus getting this at 10K and 20K,30K !!!
Wuts the problem ?
Old 08-18-14, 07:45 AM
AMNss
AMNss's Avatar
This notification can be removed by doing the following steps :
1- Brake peddle 4 times with lights off
2- Lights on ( not auto )
3- Brake peddle 4 times
4- Lights off
5- Brake peddle 4 times
6- Lights on ( not auto )
7- Brake peddle 4 times
Do the above procedure on a fresh start with parking brakes off .
Old 08-18-14, 10:55 AM
unowned
unowned's Avatar
Use your warranty
Old 08-18-14, 11:28 AM
moose66
moose66's Avatar
4- Lights off
. . . . . . . you do the hokie pokie and you turn yourself around . . . . . .geez . . . . . . hope this works! Why not just hit the dealership? Turning if off doesn't seem to get to the root of the problem!
Old 08-18-14, 11:54 AM
corradoMR2
The pursuit of F
corradoMR2's Avatar
Hmm, carbon buildup? I assume you have the 250? In N.A., a lot of injector cleaning agents are added into fuel which explains why I don't expect this "issue" for at least 80-100K km (if at all). I suspect your fuel is to blame for the issue.
Old 08-18-14, 01:26 PM
AMNss
AMNss's Avatar
I got this notification twice ( we get it every 10k , and usually the dealer forget to turn it off ). Anyway I learned how to turn it off from the dealer , and I'm sharing this knowledge to spare him a trip to the dealer.
Actually this is a standard notification that we receive every 10k. It appeared on my car at 10 , 20k and soon on 30k , so don't worry no carbon buildup issue , or fuel problem here
BTW he has a white is350 .
Bearcats98 (04-22-24)
Old 08-18-14, 01:58 PM
moose66
moose66's Avatar
AMNss, thanks for the knowledge. I notice you guys are out of the US. Don't recall seeing this topic before. Wonder if this occurs on US-spec vehicles as well? Soon to hit 10K in mine, and just wondering if this is something to look out for.
Old 08-19-14, 08:28 AM
AMNss
AMNss's Avatar
You are welcome buddy.
I saw another topic a month ago , but I'm not sure if the OP is from the US or EU regions .
Old 04-19-24, 05:26 AM
venera
10th Gear
venera's Avatar
Default 2014 IS350 Fsport
I did the brake light procedure but warning did not go away.
patriciam1
09-08-18 03:35 AM
Patr1ck
05-02-17 07:32 AM
EBMCS03
Suspension and Brakes
35
06-07-06 09:56 AM
Quick Reply: Injector Maintenance Required
