Had to buy non matching rear tire and drive 200 miles home...
Old 07-06-14, 07:25 PM
997c2
997c2's Avatar
Default Had to buy non matching rear tire and drive 200 miles home...
My RWD I350 is 2 weeks old. I got a low tire alert and found a large screw in my right rear tire, right on the tire shoulder (not pluggable). I was 200 miles from home, I have to work tomorrow. No Turanzas w/in 50 miles today. I had to put on a same size 255/35 19 but a Potenza to get home. What are my concerns on the rear diff?
Old 07-06-14, 10:15 PM
EShao350
EShao350's Avatar
You will be fine it doesn't matter it will matter if it's an subaru awd. Also it can be plugged I plugged my tires on another car right on the edge was fine for 3k miles then sold the wheels.
Old 07-07-14, 03:47 AM
997c2
997c2's Avatar
Thanks Eshao.
Old 07-07-14, 11:29 AM
moose66
moose66's Avatar
Should have no issues with the off tire provided it is sized the same as the OE tire. As for plugging, you usually can plug a tire unless the issue is with the sidewall. Plugging can be a long or short term solution. But I would not be comfortable on a plugged tire. Especially at a high rate of speed.
Old 07-07-14, 12:49 PM
997c2
997c2's Avatar
Thank you moose66. Reassuring!
go3Ds
RX - 4th Gen (2016-2022)
30
04-11-21 08:04 PM
4thGNGS350
03-07-13 04:52 PM
Wish
Wheels, Tires & Brakes Forum
06-03-12 11:16 AM
n8236
14
08-19-08 04:26 PM
f=ma
06-22-08 02:22 AM
Quick Reply: Had to buy non matching rear tire and drive 200 miles home...
