06-08's and 09-11's uses the same bar, BUT uses different kits. the 06-08's uses oem's brushing and oem's bolts. the 09-11's needs a different kind of brushing and bolts.
Any idea where I would be able to find just the brackets if I were to install on an 09+?
if you have a 06-08 f-sport rear sway bar kit, and you have a 09-11's model. you will need rear sway bar 4x bolts #90119-A0169 and 2x rear sway bar brackets #48832-30060. you can get both parts at your lexus' dealership.
