IS250/350 Fog Light Installation
Old 07-03-14, 06:58 PM
kayur33
kayur33's Avatar
Default IS250/350 Fog Light Installation
Has anybody replaced fog light bulbs in the 2014 IS250/350 (non-F-Sport)?
Video, pictures, step-by-step guide or any experience would be helpful.
I'm not trying to be rude but if you have not installed fog light bulbs on a non-F-Sport 2014 IS yourself or don't know for sure, please don't respond. I've seen posts on other forums where 'experts' give advice on what they think it should be and it's not helpful.
Thanks!
Sorry in advance if this is a repost.
I did try to search for previous posts.
Last edited by kayur33; 07-03-14 at 07:00 PM. Reason: Spelling and Minor Corrections
Old 07-03-14, 07:22 PM
Kappy550
Kappy550's Avatar
All you have to do is peel back the fender liner and twist the bulb out. Easy as can be.
Old 07-04-14, 07:44 AM
kayur33
kayur33's Avatar
Default Not that simple
Kappy you were correct.
First side took longer as I ended up removing too many screws.
Second side took 10 minutes.
You need a flat head screw driver.
Loosen the top screw under the wheel well 90 degrees.
Once the screw is out pull up on the clip and push back the fender liner.
Leave the 2 similar screws below alone and there's a push clip that you gently pull out with you flat head.
Replacing this is a little tricky.
You can now pull away the liner and get to the bulb.
I installed h11 bulbs from http://hidpowerhouse.com/shop/gs-hig...es-h11-bulb-5/.
They look a lot better.
I will post pictures when i get a chance.
Thanks!
Old 07-06-14, 01:33 AM
l5JLlll
l5JLlll's Avatar
Look at the car Manual
it has instructions for fog light installation in the maintenance section
nonames123
12-31-10 09:17 AM
Synetix250
04-10-10 09:46 PM
Bundy
Lighting
12-17-07 08:45 PM
bill_und
Hybrid Technology
06-26-07 06:35 AM
Quick Reply: IS250/350 Fog Light Installation
