So I took my 350 on a canyon-type road today
Old 06-29-14, 12:38 AM
Re3iRtH
Re3iRtH's Avatar
Default So I took my 350 on a canyon-type road today
I attached some pics
One thing, the body roll and excessive steering input needed is very noticable.
Coming from an S2000 which I had also taken to the same twisty road, this does not
inpire half the confidence.
While I love the space, comfort, and power, this handling issue needs to be addressed.
I had read about the F-sport front and rear sway bars, do you guys like yours?
What else can be done to prevent this body roll. Also, I need to turn the wheel way to much
to go around a 90-120 degree bend.
Also, anyone running aftermarket seats?
Attached Thumbnails So I took my 350 on a canyon-type road today-20140628_110744b.jpg   So I took my 350 on a canyon-type road today-20140628_113421b.jpg   So I took my 350 on a canyon-type road today-20140628_111006b.jpg
Old 06-29-14, 08:27 AM
rawr2is250
rawr2is250's Avatar
After driving with the sway bar, the car feels completely different and the handling feels absolutely amazing compared to normal. I've read its a lot of peoples favorite mod.
Old 06-29-14, 09:30 AM
Re3iRtH
Re3iRtH's Avatar
I think I will start out with the rear sway. It seems the front f sport sway is nearly the same as stock in stiffness.
Any way to tune the steering so its more responsive? Thanks for your input guys.
Old 06-29-14, 09:37 AM
darkdream
darkdream's Avatar
Just get the rear sway bar. It helps a lot, but you will still be turning your wheel alot. I currently own a s2000. The IS350 still feels like a boat compared to the s2000 even with the sway.
Old 06-29-14, 09:41 AM
metaleckz
metaleckz's Avatar
Yeah just get rear f sway bar
As for the steering response.
Get the 2012+? Isf steering ecu
Old 06-29-14, 10:05 AM
Re3iRtH
Re3iRtH's Avatar
I am trying really hard to not get an S2000 also, because I have only one covered parking included with my place and for the simplicity of owning only one vehicle
Plus they are a pain to find here in good condition and close to stock.
The 350 is a beast in a straight line compared with the s2k I must say.
Originally Posted by darkdream
Just get the rear sway bar. It helps a lot, but you will still be turning your wheel alot. I currently own a s2000. The IS350 still feels like a boat compared to the s2000 with the sway.
Old 06-29-14, 10:07 AM
Re3iRtH
Re3iRtH's Avatar
Wow you have to get the whole ECU swapped just for steering.
For anyone that has done this, do you think it was a good buy?
Sounds like an easy plug and play mod if the results are worth it.
Old 06-29-14, 11:13 AM
darkdream
darkdream's Avatar
I drove the newer IS350 with the ecu. It was noticeable, but not significantly noticeable. You probably would be disappointed coming from a S2000.
Old 06-29-14, 11:20 AM
metaleckz
metaleckz's Avatar
Well thats true. I had a miata and man ohhhh man
Edit: dont bring your car to a winding road.... problem solved
Old 06-29-14, 11:46 AM
Sffd103
Fire Slayer
Sffd103's Avatar
I had sway bars, coilovers, chassis braces. That's the best you can do. It'll never be an S2K.
Old 06-29-14, 12:48 PM
Re3iRtH
Re3iRtH's Avatar
I will get the rear sway and chassis brace. Thanks
The car came with suspension, but the last owner wasn't
sure what brand it was (he wasn't sure of a lot).
Is there a simple way to tell?
Old 06-29-14, 01:13 PM
rawr2is250
rawr2is250's Avatar
Got pics of it?
Old 06-29-14, 02:01 PM
metaleckz
metaleckz's Avatar
how about, gut the interior, put racing seats then put roll bar or some x brace then maybe?
also racing tires haha
Old 06-29-14, 02:06 PM
1sWt2GS
1sWt2GS's Avatar
the is can no way be compared to a s2k. those things are amazing in canyon runs
Old 06-29-14, 02:54 PM
darkdream
darkdream's Avatar
Still would be too heavy and not have a 50/50 weight distribution. Still would not have the direct road feel where you can put the car exactly where you want it.
Quick Reply: So I took my 350 on a canyon-type road today
