J5 AVS compatible coilover
Old 05-30-14, 11:33 AM
J5usa
J5usa's Avatar
Default J5 AVS compatible coilover
Here are few photos of the FIRST LEXUS IS F Sport AVS compatible coilovers for RWD
Mono tube design, 90% of the coilover is made out of 7075 aluminum stronger and lighter than your average 6061. Specially treated before being anodized = no corrosion.
Offered in either 12&10kg or 10&8kg or even your own custom spring rate upon availability and request.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 06-01-14, 09:43 AM
sam430
sam430's Avatar
So it's finally available? Who manufactures your spring because I've had good experience with swift?
Old 06-01-14, 05:10 PM
Mushi31
Mushi31's Avatar
Which is closer to stock spring rate? 12/10 or 10/8? I wonder who has them installed as id like to sit in it and check it out. i Live in LA where i dodge potholes left and right.
Old 06-01-14, 10:14 PM
J5usa
J5usa's Avatar
J5 utilizes a partnered factory in S. Korea and yes it is available.
Old 06-02-14, 09:45 PM
DjRiDe
DjRiDe's Avatar
When will they be available and how much? Please pm information - Thank you
Old 06-03-14, 05:30 AM
Mr_VFS1
Mr_VFS1's Avatar
Originally Posted by J5usa
We are taking orders!
AWD will ship out in two weeks.
SPECIAL PRICE
Non AVS = $1650 free shipping, ship within one week
W/ AVS= $1750 free shipping, ship within two weeks
PM to place your order.
https://www.clublexus.com/forums/sus...pension-5.html
Old 06-03-14, 12:19 PM
DjRiDe
DjRiDe's Avatar
thanks bro
Old 06-06-14, 12:09 PM
J5usa
J5usa's Avatar
Benefit of 7075 Aluminum, every part of this coils except for the bolts,nuts, springs . and to show the benefit of this high grade aluminum .. strength and weight reduction.
[IMG][/IMG]
Old 06-09-14, 03:38 PM
J5usa
J5usa's Avatar
Here's a quick video AVS working with our dampening. the clicks you here is not from our shock, its from the AVS module
[IMG][/IMG]
Old 06-16-14, 05:25 PM
unowned
unowned's Avatar
how many dampening settings are on these coilovers? If it has more than 2 can you set which is the start for the "normal" setting? How many turns more does it make when moved to sport+?
Old 06-17-14, 10:02 AM
J5usa
J5usa's Avatar
We are able to provide three positions as we need to leave room for the AVS to rotates as needed in sports + mode. after you have chosen the dampening position and install the AVS module, when set to sport+ mode the AVS module has max rotation of 110 degree which will turn as needed during your drive. Just because you set to sport+ mode doesnt mean your AVS module will turn automatically to maximum rotation of 110 degree.
I hope I was able to answer your question.
Thank you
Old 06-21-14, 05:23 PM
CTLG
CTLG's Avatar
Thank you
Does the AVS system alter dampening in the "normal" or "sport" mode at all? Also, do you specifics on when the AVS increases dampening to maximum 110 deg in "Sport +" or otherwise?
I'm very interested in these coilovers. I happen to love the AVS system but don't totally understand how it is coded to work (Lexus isn't very clear on its exact operation". This info will go along way to helping setup these coilovers properly wen I do finally purchase them for my USDM IS350 FSport.
Old 06-21-14, 11:17 PM
J5usa
J5usa's Avatar
AVS does not alter the dampening during the "normal or sport" it works during your sport+ mode.
it rotates max 110 degree when needed. as it stiffens your steering etc. Your AVS works together with other factors to provide a better handling during your more aggressive driving.
Old 06-21-14, 11:47 PM
J5usa
J5usa's Avatar
Here is a quick shot of our First Lexus IS Fsport AWD coilover.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 06-23-14, 06:58 PM
DoomBuggy
DoomBuggy's Avatar
So its my understanding that all IS250s (even if F-Sport) do not have the AVS function, correct? Im already considering swapping out my springs for coils. My AWD just doesnt look low enough, even on Super Down RS-Rs.
Quick Reply: J5 AVS compatible coilover
