Timing belt / water pump kits
There are boatloads of water pump / timing belt kits on eBay. Should I consider any of these or look at something else?
http://www.ebay.com/sch/sis.html?_kw...ump+Kit+GX+470
Former Sponsor
The ones I clicked on don't even say what brand they are.....
When it comes to Timing Belts I only trust Dealer parts or Gates belts. Water pump wise I will only go dealer parts. Remember, these are pretty expensive repairs if you don't do them yourself, and if either fails it can lead to catastrophic failure.
Not all parts are created equal - lots of Chinese crap out there.
Aisin makes the water pump etc for Toyota. There is an Amazon seller (ToyoLexus Parts Connection) that sells the complete kit which is the same as you would buy from Toyota. Another member on here has purchased the kit and compared the parts against what was removed from his truck and they are spot on.
This is a very comprehensive kit which includes the serpentine belt and cam seals too.
OEM Aisin TKT-001 Complete Water Pump Kit-Timing Belt : Amazon.com : Automotive
What should labor cost?
I also noticed that some come with a hydraulic pump tensioner (no idea what this is). Others come with a thermostat kit. Is it better to buy that way and have it done at the same time?
http://www.ebay.com/itm/AISIN-OEM-TIMING-BELT-WATER-PUMP-KIT-W-HYDRAULIC-TENSIONER-TOYOTA-LEXUS-V8-/261110179012?_trksid=p2054897.l4276
http://www.ebay.com/itm/AISIN-TOYOTA-TUNDRA-4-7L-V8-COMPLETE-TIMING-BELT-WATER-PUMP-HOSE-THERMOSTAT-KIT-/261110186075?_trksid=p2054897.l4276
Not bad. I'll likely wait until 200-210k miles to do it, but buy the parts now. Thanks.
http://www.ebay.com/itm/AISIN-OEM-TI...p2054897.l4276
http://www.ebay.com/itm/AISIN-TOYOTA...p2054897.l4276
Does anyone here know if the timing belt tensioner, hoses, and thermostat should be performed at the same time as the water pump and timing belt? This is the second timing belt service on my GX.
Personally, I wouldn't buy off of Ebay, there's a lot of counterfeit parts floating around. Someone selling parts out of their garage is a crap shoot, I've personally been scammed where someone sent me a new part in the box and it had clearly been swapped with something different. I'm sure most are legit, but the savings are usually trivial.
I would buy off RockAuto or Amazon, and would buy the Aisin kit with everything (water pump and tensioner). And I would buy new hoses, new thermostat (dealership on T-Stat) and also a new serpentine belt and radiator cap (dealer). It's worth the extra $80 or so, especially with your mileage to just get this out of the way.
I would also inspect your radiator, mine started leaking like many of them do on the lower driver's side.
Why would you buy those certain parts from the dealer and not as part of a kit or some other discount source?
Yes it is recommended, they are cheap parts and while they in there you might as well replace them.
An OEM Thermostat is like $12 whereas as an aftermarket is like $7. Some aftermarket thermostats are too universal (not the right temperature) Also, there's just a lot of failures with "AutoZone" quality aftermarket thermostats.
Radiator cap is basically the same concept. Cheap upgrade, not worth the headache to save $3-$4 on a part made in Mexico or China.
