How to choose the right map sensor
So as im getting closer to my na-t build, I am having a hard time selecting which map sensor to go with.
I understand that a 2 bar sensor you can boost up to 14 pis
3.5 bar is about 32 pis
and 5 bar up to 56 psi
I plan on running an unopen ge block (stock 10:1 compression) and e85 most of the time.
I am going to have 2 tunes, high and low boost.
Which map sensor do I want to get.
I understand the 3.5 has a lot better resolution and is more accurate than the 5 bar.
But if I want to run e85, should I be looking to get the 5 bar?
Whats the max boost on e85 on stock ge block? (I don't know if this helps but I plan on running either a s362 or s366 with the 1.00 divided a/r)
I would also just use a 3.5 bar map.
