johnnieliu,
I changed my RX330 oil filter about a month ago and I'd like to correct one thing. The oil filter of the RX330 IS NOT at the same location as the RX300. On my RX330, the oil filter is underneat of the front engine. You just remove TEN bold and 3 clips(there was a post a while ago with an instruction of how to change oil filter for RX330) and the oil filter is right there. ofter removing the plastic cover, you can remove the oil filter very easily. I found it not that difficult to replace the oil filter as the mater of fact. the hardest part I guess it would be to remove the TEN bolds, but if you have the right size socket then it's very easy to remove those bolds.
