How to get rid of red warning light, low washer fluid
Old 01-17-14, 11:43 AM
Greg5OH
Greg5OH's Avatar
Default How to get rid of red warning light, low washer fluid
im assuming the foam arm has gotten water ligged and is stuck down. Gives me tge stupid red light by message center. Can i turn it off? can i just unplug the sensor to turn the light off?
Old 01-17-14, 12:27 PM
Shmee
Shmee's Avatar
Depends on the type of switch, it's either a "close on low" or "open on low" type switch. One you can unplug to get rid of the light, the other you have to jump with a wire across the plug.
Either should be an easy fix, unless it is a resistance type sensor, then it is a bit more complicated....
Old 01-17-14, 12:36 PM
LScowboyLS
LScowboyLS's Avatar
often you can just clean the mechanism with vinegar and it will move again nicely, and then you still have all of the features!
Old 01-17-14, 01:23 PM
Greg5OH
Greg5OH's Avatar
I definitly want to keep all teh features. I shall give that a try. But i need to drive the car 500 miles this weekend and dont have time to meddle with taking the arm out. Where is that connector located to unplug?
Old 01-17-14, 01:48 PM
keyframe13
keyframe13's Avatar
Duct tape over the light maybe?!
Old 01-17-14, 01:57 PM
LScowboyLS
LScowboyLS's Avatar
I would fill the washer bottle up full with white vinegar and leave it for a few hours, and then stick hose down there and wash out the vinegar, then it will likely be working
Old 01-17-14, 02:57 PM
YoshiMan
YoshiMan's Avatar
I'm not overly familiar with the washer fluid sensor on the LS's, but i know on some cars it is simply a plastic float with a magnet on it or something, and that in time, sometimes it develops a leak and sinks to the bottom of the tank, therefore making it think that it is always empty.
You may be able to take the sensor out, dry the float out, and give it a light coating of something to re-seal it.
Old 01-17-14, 07:26 PM
LScowboyLS
LScowboyLS's Avatar
yes, YoshiMan is correct, if it is not gummed up with mineral deposits, then the float mechanism is likely leaking, both situations are very fixable
Old 01-18-14, 07:09 PM
xspsi6
xspsi6's Avatar
Just unplug it ans the light goes off which is how I got mine off took all of 45 seconds to do it.
Old 01-19-14, 12:45 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
unplug it to kill the light.
The LS has a foam float and over the years it becomes saturated. I keep an eye on my fluids so I don't care about something as non-critical as a washer level sensor and never bothered to fix it.
IIRC you can get the whole washer bottle (sans electrical components but with the level sensor gear) for like $50 from lexus, new.
Old 06-19-14, 06:24 PM
rayplumas
rayplumas's Avatar
Where is the connector on the 99 LS400 to get the low fluid light off?
Old 06-19-14, 08:32 PM
sha4000
sha4000's Avatar
It's on the bottom of the fluid reservoir in back of the bumper on the drivers side.
Old 06-20-14, 01:50 PM
steve2006
steve2006's Avatar
Repair proceedure post number 6
http://www.lexusownersclub.co.uk/for...=washer+bottle
yhchung
07-10-18 07:05 PM
xbukeye
02-26-09 10:08 PM
afang
11-11-08 11:17 AM
gqr1c3boi
04-27-08 08:06 PM
gebo
Maintenance
09-18-02 11:45 PM
Quick Reply: How to get rid of red warning light, low washer fluid
