Rattling noise on passager side
I have a bad rattling noise when I go over ruff terrain and pot holes can sum one give me an idea of what this could be
Ive seen inquiries about this problem before...could be a boatload of possible things for example broken motor mounts, lower control arm bushings, swaybar end links and bushings....etc etc. i believe i saw this on an acura forum when i was interested in a tl...pssht what was i thinking anyways i rem the problem being consistent with happening only when going over bumps and potholes...good luck with the fix
Maybe the trim on the inside connected to the moonroof, the instrument cluster bezel, or if you had the windshield replaced it could be the guide clips under the leaf shield behind the wipers. Good luck.
anesthesia
02-05-13 03:16 PM
