Is my wheel combo good fitment for ls?
I need advice whether i should keep the tires I just got. I bought some wheels 20x9 and 20x10. The tires I bought were size 245/35/20 and 265/35/20. Is this ok? I dont want super stretch. Should i keep the tires or get wider? I got michelin super sports btw. I am also slightly lowered on coils to fill tire gap. Thanks
If the rims fit to your liking offset wise and you don't have clearance issues with those tire sizes, then I don't see any issue with those tires and your rim widths. They won't be stretched.
Depends what you call stretched. The 245 on the 9" wheel will have what I would consider as a mild stretch, and the 265 on the 10" will definitely be stretched to me. I have a 245/35 on an 8.5" wheel and it seems to be the perfect width, and a 285/30 on my rear 10" wheel. Previously I had a 275/30 in the back and it had a mild stretch to it. I wouldn't want the 265, but that's just me. I really don't like any "stretch" at all.
Well I test fit my front and rear rims and they poke out past my fenders. But when I measured the offsets front would be 20x9 +44 and rears are 20x10 +51. It doesnt make any sense Unless I measured offset wrong. The front have a 2.75 inch lip and rears are 4 inch lip. The offsets should be super conservative. My tires come in wednesday and I should have them on wednesday or thurday. I will take a picture for you guys to see.
美少女戦士セーラームーン
What brand of tires will you be getting? Some seem to run wider than others. My old Hankooks ran quite a bit wide and rubbed like crazy while my same size Nittos were smaller and didn't rub.
If your car is at stock height and the wheels poke you should still be fine. I have 20/10.5 with a 45 offset in the rear of my 99 ls400 and when it was at stock height the rears poked out a lot but when lowered they tucked in nice.
If those are the offsets then they should fit fine but those are some big lips though.
masboy
Wheels, Tires & Brakes Forum
13
10-07-07 11:00 PM
