1991 LS400 Dash light turned on
Old 09-11-13, 07:00 PM
mrrbearxd
mrrbearxd's Avatar
Default 1991 LS400 Dash light turned on
Hello,
I have a 1991 Ls400
I was just about to head out of my house, and no more than 2 minutes of driving, I have noticed that my Break lights, Coolant Light, Temperature Light, Battery light turned on. The only thing that did not turn on was the Check engine light and traction light.
I have check all my fluid that is available and oil as well. Everything is all filled and nothing leaking on my drive way. Ive checked my breaks all still good.
It still cranks, idle normal. drive normal. but i dont want to risk it until i know what it may be.
My car is sitting pretty flush, and i have check all my wires, nothing was rubbing away, so i dont think it can my wiring under the fenders.
Any idea what the issue maybe or i should check to see if its the problem?
any suggestion would help greatly.
Thank you.
Old 09-11-13, 07:35 PM
RA40
Super Moderator
RA40's Avatar
That is quite the Christmas tree of lights. You'll need to plug the car in and get the codes. My first thought was the alternator has gone on permanent vacation.
Old 09-11-13, 07:44 PM
LScowboyLS
LScowboyLS's Avatar
click here for instructions on how to download the diagnostic codes!
Old 09-11-13, 10:29 PM
Gene01
Gene01's Avatar
Perhaps it could also be the known problem with the trunk hinge wiring harness?
Old 09-12-13, 01:22 AM
mrrbearxd
mrrbearxd's Avatar
Hmm, maybe but it all works perfectly fine. Unless im misunderstanding the situation, any more details about that?
Old 09-12-13, 02:27 AM
LScowboyLS
LScowboyLS's Avatar
this is the rare case where it doesn't sound like the trunk hinge wiring breakage issue is the problem, as the only lights malfunctioning are inside the dash cluster
but his is the right year range, so wouldn't hurt to check, as it is likely soon to be an issue
did you download any diagnostic codes yet?
also take a voltage reading across the battery with car off, car on at idle, and car at 2000 rpm with headlights on and post back results here
Old 09-12-13, 02:36 AM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
check the hinge anyways.
http://www.lexls.com/tutorials/lighting/bulbout.html
Old 10-03-13, 04:56 PM
mrrbearxd
mrrbearxd's Avatar
SOB, i found the problem! the problem was the alternator. GG it was plain and simple. the alternator went out on me.
Old 10-03-13, 06:20 PM
LScowboyLS
LScowboyLS's Avatar
LS400 alternators almost always go out due to a power steering leak, so be sure and check that and fix it or you will be buying another alternator in 6 months!
Vinaya
01-15-24 07:59 PM
LexusGuy91
04-10-15 11:35 PM
lslover92
08-10-09 12:30 PM
jayjw
10-04-04 07:17 AM
palmerwmd
Maintenance
10-31-02 10:28 AM
Quick Reply: 1991 LS400 Dash light turned on
