Got car back from Carbon repair
Old 10-01-13, 08:33 PM
Zatrekaz
Zatrekaz's Avatar
Default Got car back from Carbon repair
I just got my car back from getting the Carbon issue fixed, and was wondering if anyone would be able to help me decipher the invoice? I am curious to know what each of these things mean specifically. I can make some of them out, but figured someone may have more info than me.
Everything is fine with the car except for these things:
1. Only the Driver's window will go up/down from the Driver controls
2. Check VSC came on tonight
Will be calling them in the AM.
Old 10-02-13, 04:00 AM
Bichon
Super Moderator
Senior Moderator
Bichon's Avatar
The problem with the windows problem is an easy fix, covered in our FAQ sticky, and was caused by them disconnecting the battery.
You say that "Check VSC" came on. Was that with the check engine light?
Old 10-02-13, 05:42 AM
lateapex
lateapex's Avatar
Ok from top to bottom
3 pistons
3 pistons
2 oil pan, cam shaft gasket maker tubes
2 gallons super long life coolant
1 oil filter
1 engine gasket set
1 set of piston rings
24 valve adjuster assemblieeeeeees
24 valve springs
24 valve retainers
1 additional oil filter?
and a partridge in pear treeeee
Old 10-02-13, 06:59 AM
whitebeast
whitebeast's Avatar
to fix window problem
1. roll down your windows
2. roll them all the way up and hold for 2-3 second
Old 10-02-13, 02:44 PM
Zatrekaz
Zatrekaz's Avatar
I may be confusing the two... Check VSC along with a Red ! comes out at random times.
3 pistons
3 pistons
1 oil filter
1 engine gasket set
24 valve springs
24 valve retainers
So they replaced the pistons, piston rings, valve springs and their related parts, gaskets, and did they replace the oil pan or replace the gasket for the oil pan?
Thank you, will try that out.
Is there anything I should do at this point, or just drive the car like normal? I did notice my mpg is better. Got 30.5mpg on the interstate yesterday.
Old 10-02-13, 04:16 PM
Noeh
Noeh's Avatar
Drive it like you stole it
Old 10-02-13, 08:09 PM
lateapex
lateapex's Avatar
Oil pan gasket FTW
Old 10-02-13, 08:39 PM
droolerk9
droolerk9's Avatar
Default Engine repair
You also had the water pump replaced too!
If the VSC light was not on when you took the car in, the repair place should not have given the car back in that condition.
It is entirely possible that the light will go out after you've started the car several times. That is, the computer will come to grips with what it's correct state should be.
Take your car back, and have them put a scanner on your car so they can clear the DTC's if they didn't whack something while working on your car.
BK
Old 10-02-13, 08:43 PM
Zatrekaz
Zatrekaz's Avatar
So drive it kinda hard for a bit?
The Check VSC light was coming on when I took it in.
Old 10-03-13, 04:17 AM
ISMELLRICE
ISMELLRICE's Avatar
Thats wierd they replaced my water pump too bc it was "leaking"
Old 10-03-13, 12:32 PM
Gville350
Gville350's Avatar
Techincally the best method to break-in a fresh rebuilt motor is to maintain a load on the motor and no long periods of time with constained, constant speed. You can successfully break-in a motor in 15 minutes, if you simply find an empty scretch of road and accelerate quickly and then decel using sport mode and the paddles. If you have a manual trans, use the trans to "engine brake" yourself. Do this for about 15 mintues straight, you'll be golden!
Old 10-03-13, 01:22 PM
VTsuckah
VTsuckah's Avatar
It's surprising how many people do not know this
Old 10-03-13, 03:07 PM
NYKnick101
NYKnick101's Avatar
if the price says $0 at the bottom then there is nothing to decipher
Old 10-03-13, 04:52 PM
Gville350
Gville350's Avatar
Well, most Lexus owners have never rebuilt a motor/trans like I have; so such procedures are unheard of really. But I'm glad to help others with the knowledge I've gained over the years.
Old 10-07-13, 03:12 AM
Zatrekaz
Zatrekaz's Avatar
Regardless of the price, I like to be informed on what has been done to my car.
LexBrett
07-26-15 12:41 PM
gegeeee
01-14-13 01:18 PM
iainthim
03-08-07 11:27 AM
THUGRIDAH
GS - 1st Gen (1993-1997)
14
05-04-04 09:37 AM
Goods
Maintenance
10-23-02 03:17 PM
Quick Reply: Got car back from Carbon repair
