Upgrading to is350 front and rear calipers/rotors
Old 09-14-13, 09:57 PM
drewster12
drewster12's Avatar
Default Upgrading to is350 front and rear calipers/rotors
Hi,
I'm upgrading to the is350 front and rear calipers and rotors for my is250. I'm getting a pair of the larger front dust shields. Should I purchase a set for the rear as well. Will the is350 rear dust shield simply bolt on without any modification.
Also, should I worry about the shims? I'm planning to purchase some Hawks ceramic pads and thought they might come with their own shims.
Thanks in advance.
Old 09-15-13, 06:57 AM
iRyan
iRyan's Avatar
nice upgrade...i did the front but never seen the reason to change the rear...not much difference in caliper size....the dust shield should be about the same if not maybe a slight difference....you can probably shave off the piece that will touch..
Old 09-15-13, 09:19 AM
GiantsFan
GiantsFan's Avatar
Wouldn't really worry about the rear. As for shims - yes you would want to buy those.
Old 09-15-13, 11:09 AM
4TehNguyen
4TehNguyen's Avatar
rears on the IS350 are vented actually, size is about similar. IS250 rears arent vented
DickH
Suspension and Brakes
01-08-18 03:27 PM
drewster12
10-11-13 08:48 PM
MKsky
03-14-10 12:16 PM
Coconut
18
05-05-09 06:21 PM
Quick Reply: Upgrading to is350 front and rear calipers/rotors
