Weird wheel fitment
Weird wheel fitment
Hey, soo i just got my mb battles and i am extremely excited! i got the 18x9.5 +15 like most people run here. the thing is my fronts stick out like a whole inch or more and i don't know why. I"m not sure if any one has experienced this and my car desperately needs to be lowered
screen capture software
Mine's usually like that too when I jack it up. Lol
Edit: I see a lot of people giving wrong info here. Your offsets are totally fine, it's not gonna be easy fitting it since its a bit aggressive for SC's and Lexus in general. But it is doable. Just roll and pull your fenders, it'll fit nicely. And i did lower my SC. I personally have;
19x9.5 +12 225/35/19 -2.9 camber
19x10.5 +22 265/30/19 -3.9 camber
And I'm even planning on installing 5mm spacers all around to get some more poke out of it. Good luck.
lowering that car will not tuck those wheels, you need to swap to a way smaller tire first , then lower it and see
im running a 225 on my 10.5 fronts, you should be going with at least that
also are you sure the disk on all those wheels is the same? Have you tried moving the fronts to the rear and vice versa?
