Lexus GS 350 2007 - Engine is not starting!
Hi, I have a Lexus GS 350 2007 model, I was trying to start the engine, so I pressed down the brake pedal and the Start/Stop Engine button became green, so I pressed it and the engine was about to start, I removed my leg from the brakes pedal while it was starting and the engine stopped starting!! I tried to start it again but no luck! I noticed that the brakes pedal became stiff!! Panel lights can be turned on or off normally, remote Lock/Unlock works, steering wheel became slow when it goes up and down when press Start/Stop Engine button!! Does anyone have any idea what the problem is?
Note: I fully charged the battery for 2 mins but again no luck!
Sorry for my English, I appreciate your help.
Thanks!
Thanks!
Thanks worker for trying to help, really appreciated! Problem solved, I just replaced the old battery with a new one! But am still wondering why the engine wouldn't start with recharging the old battery for more than 20 mins!! I tried to recharge it from another car's battery that used to recharge a GMC Yokun!!!
Sometimes the cable isn't strong enough or has fallen useless after long usage (the jumper cables that is). I've gone through quite a few in my time when I had my Miata.... I barely drove that car and the battery always died on me.
that must be some cheap cable you bought. But than things has gone cheap quality lately. 8 gauge is not what it used to be. The size maybe 8 gauge but the material as change to other than copper. The new and improve in this upside down world.
I'm having the same problem.... When I hit the brake pedal the green light won't even come on and when I hit the button without the light on I still get no result on the push button
If you dont get the green light try putting the key fob close to the push start button
jstraayer
ES - 5th Gen (2007-2012)
05-14-24 02:56 AM
