Thread: 200k Mile Club
View Single Post
Old 05-22-13, 09:55 PM   #1
MrBooby
Trader Score: (1)
MrBooby's Avatar
Default 200k Mile Club
I made it! Had the car for 25,000 miles and a little under two years.
Click the image to open in full size.
Pictures of the car can be found here
http://www.clublexus.com/forums/es30...ore-after.html
I figured since this is such a major milestone, I should do a list of everything that I've done in that time. I hope this helps some other people who might be thinking about a high mileage ES and would like to see what will need attention.
Original Major issues:
Valve Covers and the Camshaft Seals were leaking
Radio/HVAC Lights were Burned Out
Rear Sway Bar Links were shot
Driver CV Axle was spewing grease
Dirty IACV was causing a rough idle and misfire codes
The Front Brakes were shot
Check Engine Light (incorrect oxygen sensor used)
Driver Headlight was damaged by a deer.
Mismatched Rear Tail Lamps (related to an accident)
Driver Rear Quarter Dent
Passenger Door Dent
Engine
Replaced 16 Valve Cover Bolts w/Washers
Replaced Front and Rear Valve Cover Gaskets
Replaced All Spark Plug Hole Gaskets
Raplaced All Spark Plugs
Replaced Spark Plug Wires
Replaced Intake Manifold Gaskets (both sides)
Replaced Ignition Coil Plastic Electrical Connectors (dry rot)
Replaced PCV Valve w/Grommet
Replaced PCV Valve Hose
Replaced Air Filter
Cleaned IACV Multiple Times
Cleaned MAF Sensor Multiple Times
Replaced All 3 Coolant Hoses
Drained and Filled The Whole System with Toyota Red
5 Oil Changes + Filters
Timing Belt
-Water Pump
-Idler Pulley
-Tensioner Pulley
-Hydraulic Tensioner
-Camshaft Seals
-Oil Pump Seal
-A/C Belt
-PS Belt
-Timing Cover Gaskets
Power Steering Fluid Flush
New B1S1 Air/Fuel Sensor (CA Spec)
Replaced Fuel Filter (engine bay)
Tried to Figure out The Source of Low Fuel Pressure
Replaced Fuel Pump
Replaced Fuel Pump Sock
Replaced Fuel Filter (gas tank)
Replaced Fuel Pressure Regulator (gas tank)
Transaxle
Drained and Filled ATF (3 Times) with AMSOIL
Replaced Transmission Filter
Replaced Transmission Pan Gasket
Replaced 17 Bolts for the Pan
Replaced Driver CV Axle
Suspension
Replaced All 4 Sway Bar Links w/Moog Problem Solvers
Front and Rear Whiteline Sway Bars with new Bushings
Tokico Blue Struts
Tanabe DF210 Lowering Springs
Toyota Mounting Hardware (every little piece)
Four-Wheel Alignment (3 times)
Brakes
Replaced Front Brake Rotors
Replaced Front Brake Hoses
Replaced Front Brake Calipers
Replaced Front Brake Pads
Brake Fluid Flush
Painted Front Brake Calipers
Tires
Patched Original Rear Passenger Tire
New Michelin Xice Xi2 Winter Tires on Original Wheels
New Hankook Ventus V12 Evo Summer Tires on 17" GS300 Wheels (215/50/17)
Lights
Replaced Driver Side Headlight
Replaced Driver Side Corner Light
Replaced Rear Inner Lamps (2000-2001 MY) to Complete the Package
Polished the Passenger Headlight
Replaced Fog Light Bulbs
Replaced Rear Brake Bulbs
Replaced Front Signal Bulbs
Replaced Low Beam Bulbs
Replaced License Plate Bulbs
Replaced Rear Inner Parking Light Bulbs
Replaced Rear Outer Most Parking Light Bulbs
Replaced Outer Tail Light Gaskets (dry rot)
Replaced the Burned out Climate Control Bulbs
Resoldered the Radio Bulbs
Miscellaneous
Replaced the Battery
Cleaned All Leather with Leatherique
Cleaned All Carpeting with the Rug Doctor
Cleaned the Front Seat Belts
Cleaned the Speaker Covers
Clay + Machine Polish + Wax
Replaced Both Remote Batteries
2 Sets of Wiper Blades
Washer Fluid
Replaced 6 Rusty Exterior Mirror Screws
Cleaned the A/C System with the Toyota A/C Refresher Kit
Dusted the A/C Vents with Compressed Air
Installed a Cabin Air Filter
Lubed up the Steering Column
Touched Up Some Body Damage
Popped out a Dent in the Rear Bumper
Wrapped the Steering Wheel with a Brown "Wheelskin"
Future
Remove and Replace Exhaust Y-Pipe (Noisy Catalytic Converter) Done
Replace Rear Rotors and Pads Done
Replace Noisy Alternator Pending
Replace Floor Mats with Lexus ones Done
MrBooby is offline   Reply With Quote
