Vibration Question
Vibration Question
I recently obtained a 06 GS300 Non AWD. There seems to be a vibration in the seat at 75-80 MPH after you let off the gas. Is that Drive shaft or Tire Balance problem?
No, all bone stock. The tires are also directional. Ive also read on here the type of balancer also matters?
It's either the tires or the rims most likely. As stated go get the wheels balanced to see if it gets rid of the problem. If not take it back to them and see if they can locate a bend in the rim or a low spot on the tires. Sometimes when a car sits on a lot for a very long time they develop low spots in the tires. You may need to take it to a shop that specializes in fixing tire/rim issues if the wheel balance does not fix the issue.
The way I read/comprehend your post is your car is smooth until you let off the gas? As in at 75-80 cruising down the road its smooth yet the moment you take your foot off the gas the vibration begins?
If my questions above properly reflect your issue then wheel balance is probably not your source of the vibration. Rotation and balance is a quick and relative easy diagnostic step but if smooth to begin with you could just be wasting your money. More likely is transmission, driveshaft or axle shaft/CV joint issue.
I will cross my fingers its the tires yet if its the way you describe it, you probably have something more $$ to deal with..
Let us know
That is correct
BPlak,
Let us know
Let us know
sarah
Wheels, Tires & Brakes Forum
07-22-15 11:41 AM
johncoby
ES - 5th Gen (2007-2012)
11-20-14 11:20 AM
silver305
06-13-13 01:35 PM
mndaves
10-09-08 09:34 AM
