Front Cigarette Lighter not working...HELP
Old 12-11-12, 06:49 PM
GreenUCF20
GreenUCF20's Avatar
Default Front Cigarette Lighter not working...HELP
My front Cig lighter does not work and I need it to charge my phone. Please any info would help.
Old 12-11-12, 06:51 PM
dengman
dengman's Avatar
this has been asked many times. did you search? did you check your fuse?
Old 12-11-12, 07:10 PM
hotdawwg
hotdawwg's Avatar
Funny, My charger stopped working so I went to check the cable and noticed a lot of corrosion dust in my cig plug. any possible ideas?
Old 12-11-12, 07:27 PM
LScowboyLS
LScowboyLS's Avatar
it is normally the fuse link, which is inside the lighter socket mechanism - search on here for how to remove it entirely!
Old 12-12-12, 12:20 PM
hotdawwg
hotdawwg's Avatar
for me?????????????
Old 12-12-12, 01:04 PM
LScowboyLS
LScowboyLS's Avatar
LS400 cigarette lighter power socket fuse link fix
Old 12-12-12, 06:13 PM
Yamae
Yamae's Avatar
I find some Americans are really kind and informative.
Toyota sets up double methods to prevent a fire or a smoke problem at the cigarette lighter line. One is a fuse in the fuse box and the other is a fusible link attached to the cigarette lighter box itself. You need to check both.
Old 12-12-12, 06:20 PM
LScowboyLS
LScowboyLS's Avatar
yes, the cigarette fuse link is an unusual extra feature that Toyota has implemented to prevent a fire from a stuck-on cigarette lighter, but fortunately, very few LS400 drivers smoke inside their car these days, they mostly use the cigarette lighter as a 12V port to charge a cell phone, so therefore I recommend people just remove this fuse link feature when it fails open (as mine did)
Old 12-12-12, 06:31 PM
JradCelly
JradCelly's Avatar
mine had rust all over the contact at the bottom of the socket just dremel or sand that contact point until you see bar metal . it worked for me, my Sirius adaptor worked after I scraped off the rust. I was just doing it in a hurry but a better job could be done if u take some time
Posted from ClubLexus.com App for Android
SoCal Cyco
12-01-22 04:29 PM
edvc520
12-01-22 09:46 AM
SLVRGS
03-31-22 10:30 PM
smarshall9
SC- 1st Gen (1992-2000)
03-20-09 04:53 PM
mcnelson
08-05-02 05:13 AM
Quick Reply: Front Cigarette Lighter not working...HELP
