charging system warning light on?
Old 08-31-12, 08:17 AM
redrocks
redrocks's Avatar
Default charging system warning light on?
Noticed the warning indicator on dash,linage of a battery, this morning. Thought maybe battery needed to be replaced? So got replacement battery and installed it, but warning light still on. Ideas what could be wrong?
Thanks.
Old 08-31-12, 10:16 AM
SouthernSS
Former Sponsor
SouthernSS's Avatar
did you get your alternator checked for proper operation? If not, you may be damaging that brand new battery too.
Old 08-31-12, 11:50 AM
caha14
caha14's Avatar
Chances are your alternator is not charging the battery, so you'll want to drive to a shop/dealership that's preferably nearby, and keep you AC and other accessories off so that you have enough juice to get there (in case it is the alternator isn't charging).
Old 08-31-12, 12:49 PM
redrocks
redrocks's Avatar
Thanks for the recommendation.
Old 09-01-12, 07:59 AM
telmz1
telmz1's Avatar
I had the same situation a few months back and had to replace the alternator. Luckily I was able to get home when my whole navigation system kept turning off and on whenever i hit the brakes.
Old 09-01-12, 08:01 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Reset the ECU to rid the light and see if it comes back...if it does, your alternator is probably the issue.
Old 09-01-12, 02:51 PM
redrocks
redrocks's Avatar
Is "resetting the ECU" just a matter of disconnecting the battery?
Old 09-01-12, 04:40 PM
Booyah
Booyah's Avatar
I think it would be beneficial to go get it checked
Old 09-01-12, 05:08 PM
redrocks
redrocks's Avatar
Absolutely, got an. Appointment for other work next Tuesday and will have this Checked
Old 09-01-12, 06:33 PM
caha14
caha14's Avatar
Great. I'm assuming you won't be driving it between now and then? If your alternator is not charging, the truck will shut down on you if you drive it long.
Old 09-01-12, 08:31 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Disconnecting the negative battery cable will reset the ECU. As well as pulling the fuse.
Old 09-02-12, 04:03 AM
redrocks
redrocks's Avatar
Thanks, I will try it.
Old 09-02-12, 06:32 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
The charging system light is not a light that is triggered by a code set in the ECU - it is triggered by low charging voltage or low system voltage - when the problem goes away, so does the light.
If the vehicle has a new battery that is good, all of your grounds are proper and fuses are in good condition (including the alternator or main fuse), then, pretty much the only other alternative is the alternator... I would park the truck until I was ready to get it checked or fixed.
There is an easy quick check you can do in your driveway with a simple voltmeter... Start the truck, put the voltmeter leads on the battery terminals. less than 13 volts, faulty alternator, more than 14.5 volts, faulty alternator - those two are dead giveaways... between the two, the alternator could still be bad, just not putting out enough amperage...
Old 09-02-12, 10:44 AM
redrocks
redrocks's Avatar
Seems like it's the alternator. Kind of disappointed that this would need replacing with only 71K on an 06 GX. I've had Hondas and Acuras, all with over 150K miles on them and never had to replace their alternators. One would expect a GX to have a heavy duty alternator? Oh well...
Old 09-02-12, 10:48 AM
mitsuguy
mitsuguy's Avatar
unfortunately, all alternators are built pretty much the same... that being said, 71k is not terribly long, but things happen... main cause for alternators going bad is some sort of fluid contaminating them... most alternators on Toyota vehicles go 200k plus, same as Hondas and Acuras, but, they still go bad...
Quick Reply: charging system warning light on?
