LS 460 - DIY Oil Change
Help. I want to change my own oil. I cannot find any procedures for how to do this (in fact, i cannot seem to even find the Oil Filter). Help please!
Recovering Lexus Addict
The LS460 forum has a number of threads on this. Do a search on oil change in the title of threads in that forum
Example:
https://www.clublexus.com/forums/ls4...re-w-pics.html
Example:
Get some ramps esp. Raceramps @ raceramps.com made of solid synthetic rubber [used in the space shuttle].
Open the trap door.
Remove the top oil cap.
Drain the old oil into a a pan.
Buy a SST Special Service Tool from Lexus, to remove the oil filter cannister.
Attach a 3/8" square socket drive to the SST, to remove the oil filter cannister.
Remember to clean the oil filter cannister thoroughly with detergent, rinse thoroughly, and dry thoroughly.
Buy a new oil filter from Lexus, and insert it into the cannister.
The new oil filter from Lexus also contains a couple of brand new rubber o-rings.
Smear oil around the rubber o-rings.
Tighten.
Refill the oil.
Best to use fully synthetic 5W30...
Open the trap door.
Tighten.
Refill the oil.
On the other hand, a small amount of old oil isn't going to make a significant difference since you're putting in 9.0 quarts instead of 9.1.
Yeah, it depends on the oil pan design how much will be left in the pan.
About 12 years ago I decided no more lying under cars for me so I bought a Mohawk 9,000lb lift. Which brings me to my next point - the LS is not well-equipped to be lifted as the factory lift points are small and flimsy.
i bought a set of raceramps and they work great. $203 on amazon and free shipping for the 56" long ones.. had them in two days. the oil actually drains better with the car on the ramps because the drain plug is in the rear of the pan. as well as the ls460 the ramps work well for the toyota sequoia suv, the smart car, the john deere tractor, the john deere zero turn mower and anything else that i want to get under. very useful tool.........bud
always pretty simple to just take it to a shop. Its pretty damn cheap and a lot less time. I applaud you DIY guys. I just dont have the time, patience, or skill. I wish I did....
I was thinking the same thing. I've never changed the oil on my LS so I don't know how that position affects a complete drain. However, you know a dealer has the vehicle level so it would seem that Lexus would design the drain to accomodate that position.
