How to Replace 98 GS300 Brake Master Cylnder Booster Unit
My car has 195,000 miles and somewhere in my master cylinder i have been hearing a loud squeal that sounds like a dolphin when pressing or releasing the brakes. This used to occur only in freezing temperatures but over the last 2 years this has become worse and will do it when 100 degrees. For the past 5 years my brakes feel a little mushy as if needing bleeding.
I asked a Lexus dealer about it this week and was told the electronic actuator is probably about to fail and will lose my breaks. The replacement labor and parts is not worth it and would like to change this myself with a used one. Does anyone have knowledge on how to replace the unit and how hard it is to do? Thanks.
Thanks for all your help. I bought a 1999 ABS unit out of a salvage yard for $450. There was really nothing complicated about removing and installing it but it took 3-4 hours because I had a hard time getting the right angle on the 4 firewall bolts. Once installed I had it towed to a Lexus dealer who bled the system for $112. Other local mechanics said they would not bleed the brakes and that I had to have a dealer do it. My brakes work better now than they ever did. The salvage guy said the 98 and 99 models are well know for faulty ABS systems and finding a cheap used one is getting a more difficult.
I had read about using newer ABS units but when I went to the salvage yard the guy told me only 98 and 99 ABS brakes were compatible so that's why I went with the 99 model. I didn't have time to look into it more and just bought it. I hardly knew what I was doing anyway.
this guy used a supra one
https://www.clublexus.com/forums/gs-...ter-build.html
i have a supra one thomas, but it has abs or else i would trade you
I need help anyone who have a brake booster for a GS300 and they are selling it let me know ASAP 1347-545-8231 thanks
