How to Replace 98 GS300 Brake Master Cylnder Booster Unit
Old 05-05-12, 07:47 PM
Mick2
Mick2's Avatar
Default How to Replace 98 GS300 Brake Master Cylnder Booster Unit
My car has 195,000 miles and somewhere in my master cylinder i have been hearing a loud squeal that sounds like a dolphin when pressing or releasing the brakes. This used to occur only in freezing temperatures but over the last 2 years this has become worse and will do it when 100 degrees. For the past 5 years my brakes feel a little mushy as if needing bleeding.
I asked a Lexus dealer about it this week and was told the electronic actuator is probably about to fail and will lose my breaks. The replacement labor and parts is not worth it and would like to change this myself with a used one. Does anyone have knowledge on how to replace the unit and how hard it is to do? Thanks.
Old 05-05-12, 10:23 PM
rgarjr
rgarjr's Avatar
I used to have the same problem with mine, very annoying hearing that sound everytime you pressed on the brake pedal. Bought a used master cylinder/ABS pump unit and think I paid no more than 150 for the labor.
Old 05-06-12, 09:37 AM
AMSMIKE
AMSMIKE's Avatar
remove the 4 lines from the unit itself
unplug all electrical connectors and sensors
remove the pin going through the brake pedal
remove the 4 bolts holding the booster to the firewall (inside the car)
pull the booster assembly out
Old 05-06-12, 08:09 PM
Mick2
Mick2's Avatar
Thank you very much. I think I will track down a used one and attempt replacing it. Appreciate the help!
Old 05-06-12, 09:45 PM
AMSMIKE
AMSMIKE's Avatar
most people upgrade to 01+
do some searches
Old 05-07-12, 12:30 PM
Mick2
Mick2's Avatar
So then.... do 01+ master cylinder assemblies replace the current unit without modification?
Old 06-08-12, 07:58 AM
sinistervr
sinistervr's Avatar
i dont know if it needs modification i would think not, but the 01 plus is better
Old 06-08-12, 11:46 AM
Mick2
Mick2's Avatar
Thanks for all your help. I bought a 1999 ABS unit out of a salvage yard for $450. There was really nothing complicated about removing and installing it but it took 3-4 hours because I had a hard time getting the right angle on the 4 firewall bolts. Once installed I had it towed to a Lexus dealer who bled the system for $112. Other local mechanics said they would not bleed the brakes and that I had to have a dealer do it. My brakes work better now than they ever did. The salvage guy said the 98 and 99 models are well know for faulty ABS systems and finding a cheap used one is getting a more difficult.
Old 06-08-12, 12:21 PM
sinistervr
sinistervr's Avatar
why didnt you choose to go with the 01 and up?
Old 06-08-12, 12:27 PM
speedaddic
speedaddic's Avatar
I'd like to remove my ABS all together....
Old 06-08-12, 07:48 PM
Mick2
Mick2's Avatar
I had read about using newer ABS units but when I went to the salvage yard the guy told me only 98 and 99 ABS brakes were compatible so that's why I went with the 99 model. I didn't have time to look into it more and just bought it. I hardly knew what I was doing anyway.
Old 06-08-12, 09:07 PM
AMSMIKE
AMSMIKE's Avatar
I did. best thing I did!
https://www.clublexus.com/forums/sus...nd-master.html
Old 06-09-12, 05:51 AM
sinistervr
sinistervr's Avatar
this guy used a supra one
https://www.clublexus.com/forums/gs-...ter-build.html
i have a supra one thomas, but it has abs or else i would trade you
Old 03-09-13, 11:18 AM
KAJmapper
KAJmapper's Avatar
if you do end up replacing your master cylinder/brake booster components can I buy the old broken ones from you ?
Please pm me
Old 06-07-13, 10:18 PM
Leonraghoo
Leonraghoo's Avatar
I need help anyone who have a brake booster for a GS300 and they are selling it let me know ASAP 1347-545-8231 thanks
Quick Reply: How to Replace 98 GS300 Brake Master Cylnder Booster Unit
