any one ever installed a toms/trd push button start
Old 02-11-12, 03:36 AM
gerill2p
gerill2p's Avatar
Default any one ever installed a toms/trd push button start
Anyone has a diy here? Should i get one? Any reviews from the people the did this?
Thanks
Will
Old 02-20-12, 06:57 AM
Vroomin350
Vroomin350's Avatar
any more info on this?
Old 02-20-12, 11:51 AM
Gville350
Gville350's Avatar
?Por que'?
Old 02-20-12, 04:15 PM
o7iS250
o7iS250's Avatar
x2, I definately wanna know.
Old 02-20-12, 05:07 PM
GiantsFan
GiantsFan's Avatar
Yes.
Use search
Old 02-21-12, 06:51 PM
gerill2p
gerill2p's Avatar
Search dnt wrk on my phone
Old 02-21-12, 07:03 PM
Marexus
Marexus's Avatar
should be simple, remove the steering wheel and plastic aurround. Then remove the gauge cluster and reach your hand in and pop out the stock one and pop the new one in.
Old 02-21-12, 07:18 PM
shiny250
shiny250's Avatar
From what I remember, you have to take off the chrome surround around the start button. Then twist or wiggle the button unit until it comes out. Unplug the wiring from the back, plug it into the TRD start button and put everything back.
Now I don't have the TRD start button but I did have to take it out when I was replacing all my LEDs. It was a bit easier to have the center dash unit taken out so that you could reach in the back and unplug the start button. After unplugging it, its easier to pull the button out.
Hope this helps. Goodluck!
Old 02-23-12, 07:58 AM
LyleBeach
LyleBeach's Avatar
Found this link:
http://www.tomsracing.co.jp/english/...24-143416.html
Old 02-29-12, 12:07 PM
llamaboiz
llamaboiz's Avatar
just put it in this morning, PITA till i figured out a easy way so let me give everyone a few tips, use a panel puller to get the chrome bezel off (thx ISBU) then take a paper clip and bend one end into a L shape (not a big L but just a hook kinda thing), slide the paper clip between the button and the~ 'outside ring black thing', use a needle nose pliers to grip the clip and pull~ watch out thou cuz the clear plastic for the light to shine thru the button will go flying along with the button, stuff a towel to cover the seatbelt area so it doesn't fall in there~ when you put the chrome bezel back on you'll need to line up the tabs so dont just mash it back in.
Old 02-29-12, 12:13 PM
2jzism
2jzism's Avatar
man I just don't understand why Toyota uses GREEN lighting???? Why
Old 02-29-12, 12:16 PM
evogt500
evogt500's Avatar
Toyota did research and found the color green is the easiest on eyes.
Old 02-29-12, 03:48 PM
gerill2p
gerill2p's Avatar
Thanks for the info everyone, now time to buy....
Old 02-29-12, 04:12 PM
omgitsjoe
omgitsjoe's Avatar
Looks good though i remember at one time there was a start button like this that was RED instead and that i'd prefer neveretheless a nice mod !!
Old 02-29-12, 04:16 PM
rookieIS
rookieIS's Avatar
Red = TRD
Quick Reply: any one ever installed a toms/trd push button start
