IS-F / Sport Steering ECU
Old 11-26-11, 09:59 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Default IS-F / Sport Steering ECU
Has anyone swapped an 09+ Sport Package power steering ECU into their non-sport car before? I have the steering damper, sport suspension and F-Sport sway bars already. I've ordered the ECU and am going to try it next week sometime, but I was just curious if anyone had done it before.
I have no idea what to expect (there aren't many sport package or F-Sport cars in Canada), so I'm just going out on a limb here, haha.
Jeff
Old 11-26-11, 10:54 AM
ALLCHILL
ALLCHILL's Avatar
interesting. Let us know what you think after the install. Also, how much did this cost?
Old 11-26-11, 11:23 AM
edgeucated
edgeucated's Avatar
Im looking forward to your DIY! especially If this isn't too hard of an install
Old 11-26-11, 11:37 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
The main issue with the install is that you need a Techstream to do the initial calibration after installing the ECU, so it's not something you can do without access to a Techstream or Techstream Lite.
Just saying, the install itself will be relatively easy (it's just under the battery), however I'm not sure how DIY friendly it is, since you'll likely need a dealer to do the initial calibration after the install.
Jeff
GiantsFan
GiantsFan's Avatar
Currently I have the ISF steering damper. Curious to what the ECU will do.
Looking forward to your writeup!
Old 11-26-11, 11:49 AM
BAY2LA350
BAY2LA350's Avatar
I'm interested in this as well! I know when i went with the IS350 I was sacrificing road feedback/handling in comparison to a 335i, but if the sport ECU can help, that would be awesome!
I'm not a non-sport, with sway bars.
Old 11-26-11, 02:19 PM
Gville350
Gville350's Avatar
In for results...though I already have a sports pkg.
Old 11-26-11, 02:44 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
06-08 IS models used the same ECU whether it had sport package or not, only 09+ have a different ECU with sport package.
The X-Package of course also uses the same ECU as the sport package cars, as it has the sport suspension setup.
I've also contemplated getting the IS F ECU, but I figure it's safer to go with the ISx50 one.
Jeff
Old 11-26-11, 03:50 PM
Gville350
Gville350's Avatar
^Ah, good info. So what's the cost on that specific ecu?
Old 11-26-11, 04:44 PM
edgeucated
edgeucated's Avatar
well my dreams are crushed haha
Old 11-26-11, 06:23 PM
SCWB
SCWB's Avatar
Without changing any hardwares, how much different a steering ECU can make? I'm curious. In terms of road-feel and steering ratio, these two attributes are contributed heavily by hardware setting.
Old 11-26-11, 06:41 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Of course the rack ratio is mechanical and cannot change, but the assist in the IS is entirely electrical and controlled by the computer. It handles how much assist there is and when it gets applied based on vehicle speed, and torque. The steering computer has complete control over how the power steering assist functions. Honestly I don't know how much different the sport package ECU is, but I hope just enough that I like it even more.
Jeff
Old 11-27-11, 08:01 PM
SCWB
SCWB's Avatar
Great explanation. Please let us know the result. Thanks Jeff.
Old 11-27-11, 10:53 PM
getfunky
getfunky's Avatar
Subscribed. If this makes noticeable difference then I'm definitely adding this to my list of mods.
Old 11-28-11, 10:17 AM
itruns
itruns's Avatar
Default I'm in as well
I'm in as well. I don't know how much difference it will make though.. A coworker swapped a 2010 IS250 for a IS250 F-sport and says the steering feels the same to him.... but he is a bit odd so...
I know the ISF feels different (heavier/firmer) but it could be the added weight of the V8..
I've got a good idea how to make it adjustable... but haven't had the time to build the test module to try it out...
Very interested to hear the results and the COST info....
Quick Reply: IS-F / Sport Steering ECU
