DIY: IS-F front brake rotors
Old 11-25-11, 07:02 PM
caymandive
11 Second Club
caymandive's Avatar
Default DIY: IS-F front brake rotors
Original rotors and second set of pads with 35k on the odometer, my last track session finally resulted in needing a complete front brake job. This thread is specific to the rotors, but in step one I have a link to pad only replacement.
Most everything you need for this project:
1. New Rotors/pads (Raybestos rotors ordered from RockAuto.com and the pads are OEM)
2. Brake Cleaner
3. WD-40 or equivalent to spray the hub
4. Disc brake lube for back of the shims
5. C-clamp or flat head screw driver to push the pistons back in the caliper
6. Hammer and Pin-punch to tap out the top pins
7. 13 and 17 mm sockets
8. M8x1.25 bolt to help remove the rotor
9. Torque bar
10. Towels and Gloves
Step One
Remove old brake pads as described in this thread.
Step Two
After removing the pads you can then remove the (2) 17mm bolts that hold the caliper in place. This is what you should then have. (2) pins, (1) center bolt, (1) anti-rattle clip, (2) 17 mm bolts and (2) very worn pads. (notice the hair line cracks! I definitely won't be using stock pads at the track again.
When you remove the caliper place it on something such as a bucket to prevent damage.
Step Three (optional)
If you have a micrometer you can check the thickness of the rotors. They call for replacement at 28mm in the front. I measured 28.75, which is close enough for me.
Step Four
Spray some WD-40 or equivalent around the center hub. After about a minute take that M8x1.25 bolt and tighten into the rotor until the rotor (pops) free. My rotor was loose enough that just the one bolt was enough.
Step Five
Remove old rotor and then remove any rust/debris around the the hub area to ensure the new rotor is able to sit flush.
Step Six
Install new rotor ensuring that it is fully seated against the hub. Once positioned I used a lug nut to temporarily hold the rotor in place. <<<<<< Just don't over tighten. With the rotor in place you can remount the caliper and torque to spec.
Step Seven
Install the new pads as shown in this thread
Step Eight
Double check that you tightened everything down and put your wheel back on ensuring you torque to spec.
Final Steps
- Double check everything including your brake fluid reservoir cap!
- Put your wheel back on and torque the lug bolts to spec
- Embed the pads to the rotor properly. I do several 60 to 10mph slow downs. Do not come to a complete stop!
- Clean up and savor the money you just saved by doing this easy brake job yourself.
AndrewISF (02-26-17)
Old 11-25-11, 07:08 PM
streetx
streetx's Avatar
nice write up!
need to do my brakes soon
Old 11-25-11, 07:43 PM
Kingkrs
Kingkrs's Avatar
Outstanding sir! Much appreciated especially since I will be needing to do this real soon.
Old 02-07-12, 09:10 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
Something to keep in mind - Cole said 28mm is minimum thickness but his measured 28.75 - close enough for him - he's throwing away a rotor with 37.5% of its service life left. You only have 2mm of wear from the original 30mm. If you're concerned about keeping costs down, you'll run it to 27.99mm...
Old 02-07-12, 09:59 PM
SeanGTS
SeanGTS's Avatar
Do we have a sticky section for all of these great write ups? Or an archive of sort?
Old 02-09-12, 07:36 AM
IS350atWOT
IS350atWOT's Avatar
Do you know the torque settings needed?
Old 02-09-12, 08:39 AM
dano9258
dano9258's Avatar
Great job! I agree with SeanGTS, we need to set up a sticky area with these write ups. I already found the DIY oil change posts, and would love to be able to find this one quickly as well.
Old 02-09-12, 04:11 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Caliper bolts are 58 lb-ft (78 Nm), bridge bolt is 22 lb-ft (30 Nm).
Old 02-09-12, 07:44 PM
g35cali
g35cali's Avatar
Thank u subscribed
Old 02-10-12, 02:50 PM
dsg03svt
dsg03svt's Avatar
Is there a typical mileage one should expect to get out a non-tracked rotor? I don't own a micrometer and don't want to go out and buy one to check, if my rotors w/ 42,000 miles on them still have plenty of life left in them.
Also, does this differ from the fronts to the back?
Thanks
Old 02-10-12, 04:01 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
There is no typical mileage. It takes me an eternity to wear out rotors, and yet I've seen guys on this site claiming their rotors were shot in less than 20k miles. Honestly, I think many people get taken for a very expensive ride when it comes to brakes.
Minimum thickness is different front and rear, but it is stamped in the rotor hat so you don't need any reference manual, you can just get the number off the rotor.
A micrometer isn't essential. You can use a caliper, and even a pretty inexpensive dial caliper will be good enough for measuring rotors. The danger of going too thin is primarily cracking with a very slight chance the rotor will actually break apart. This is incredibly unlikely at street speeds. Taking a thin rotor to the track is a whole different consideration, and something I wouldn't choose myself. I have seen guys competing with rotors cracked beyond limits and they've still maintained basic integrity.
Old 02-10-12, 05:28 PM
NERD42
NERD42's Avatar
Awesome! I did my own front breaks (pads & rotors) a couple months ago they are very easy to swap.
I have 41k miles on my '08
I recommend people to do them yourself and save a lot of money without taking it to the dealership.
Old 02-13-12, 01:41 PM
iH8RICERZ
iH8RICERZ's Avatar
Bookmarked! Thanks for sharing this DIY... definitely gonna save myself some $ when its time.
Old 02-20-12, 12:44 AM
ISFFF
ISFFF's Avatar
VERY useful info. really gr8.
I printed the info and will cherish it.
Old 02-20-12, 06:18 AM
F1nALMSfan
F1nALMSfan's Avatar
Great info, thanks for taking the time to document it!
Quick Reply: DIY: IS-F front brake rotors
