Speed Sensor Wire location
Old 11-05-11, 06:27 PM
Emilaman
Emilaman's Avatar
Exclamation Speed Sensor Wire location
HI, People!
I'm trying to install avic D2 to my RX330 (2004), and i need to connect HU to speed sensor wire (VSS). Where is that wire?
Thanks!
Old 11-05-11, 10:56 PM
mkorsu
Zombie Slayer
mkorsu's Avatar
At the ECM, which is to the right of the glovebox. Pin # 17, Light Green. Will show AC voltage.
Old 11-06-11, 01:09 AM
Emilaman
Emilaman's Avatar
Thanks a lot!
Do you have wiring diagram for ECM?
Old 11-13-11, 05:55 PM
Emilaman
Emilaman's Avatar
can anybody post here picture of this wire?
Old 11-14-11, 07:50 PM
Emilaman
Emilaman's Avatar
Yoo, people! Anyone, please post picture of location where is that wire!
Old 11-15-11, 05:38 PM
Shibumi1
Shibumi1's Avatar
no pics avail on directechs..but you can also try ECM, second plug from top, pin 17 lt green wire (behind glove box) or
The VSS wire is also lt. blue at the amplifier under the passenger side rear seat.
Old 11-15-11, 06:22 PM
Emilaman
Emilaman's Avatar
Thank You for your response! I cant find this ECU module. I opened the glovebox and only thing i see is Cabin air filter compartment!
PS. What this VSS doing on amp? are you sure about that blue wire on non navigation amp?
Old 11-15-11, 08:15 PM
Emilaman
Emilaman's Avatar
Oh yeah i found this ECM, but God help me, i never saw so many wires in one tiny place!
Here is the ecm photo, so which one is the VSS?
Old 11-16-11, 04:01 PM
Shibumi1
Shibumi1's Avatar
disconnect the neg batt terminal... then with the ecm mounted in the vehicle(or held up like its mounted) unplug the 2nd harness from the top.. look at the wire side of the plug... should have #'s at each corner.. locate the # closest to 17 an count over til u locate a light green wire it should be in pin 17 if u counted properly..
Old 10-28-19, 08:56 PM
boosteddsm
boosteddsm's Avatar
Waking this thread from the dead. Looking for the speed wire on a 2009 RX350. Looking at the ECU harness the 2nd from the top, I see no light green wire, just a normal color green wire. I've search every way I know how on here and across the internet to no avail. Any help greatly appreciated!
Old 01-19-20, 11:18 AM
zakirrrr
zakirrrr's Avatar
Did you managed to find it?
I'm looking sane for my GS350 2009 + reverse signal wire
tritron
Performance & Maintenance
07-29-09 08:49 PM
Luxor
05-18-09 09:31 AM
DjFergi
03-16-05 06:46 PM
Quick Reply: Speed Sensor Wire location
