O2 sensor warranty
Old Oct 20, 2011 | 06:15 AM
Bichon's Avatar
Bichon
Default O2 sensor warranty
Does anyone know how long these are covered? My CEL came on Wednesday with a P0420 code, and from doing some searching it appears that a bad oxygen sensor is a likely culprit. I'm at 5 years, 10 months, and 67,000 miles, and was curious to know whether they would be covered under either the powertrain or federal emissions warranty.
Old Oct 20, 2011 | 06:38 AM
quick123's Avatar
quick123
P0420 is for the bank 1 catalytic converter operating below threshold...has a 8 year/80,000 mile federal emissions warranty
Old Oct 20, 2011 | 07:14 AM
Bichon's Avatar
Bichon
I know that the catalytic converter is covered, but a P0420 can also be caused by an exhaust leak or bad O2 sensor, so my question was whether these were covered.
Old Oct 20, 2011 | 07:53 AM
calvin2376's Avatar
calvin2376
I'd just call a local dealer and ask.
From Lexus' website, it looks like they're not covered by powertrain warranty:
Powertrain Warranty
The Powertrain Warranty is for 72 months or 70,000 miles, whichever occurs first. Except for the situations listed on the Basic Warranty page, this warranty covers repairs needed to fix defects in materials or workmanship of any component listed below:
Engine
Cylinder block and head and all internal parts, timing belt and cover, flywheel, oil pan, water pump, fuel pump, engine mounts, engine control computer, seals and gaskets
Transmission and Transaxle
Case and all internal parts, torque converter, clutch cover, mounts, engine control computer, seals and gaskets
Rear-Wheel Drive System
Differential carrier assembly, driveshaft, axle carrier, axle case, axle bearing, axle shaft, seals and gaskets
So if it's covered it would be under the Emissions warranty. Have you checked the warranty booklet in your car for the Emissions warranty info? I can't find it on their website.
Old Oct 20, 2011 | 07:57 AM
Maxximus's Avatar
Maxximus
don't think they're covered...mine was ripped off while driving in a snow storm 2 years ago. deal wanted 800 for it, car was brand new at the time. I knew the manager since he worked at another place so he carefully rewrote it as a warranty thing other I was screwed.
Old Oct 20, 2011 | 08:27 AM
Bichon's Avatar
Bichon
Yeah, I finally threw in the towel and brought it in from the glove compartment.
Looks like a very limited number of items are marked as having 8/80 coverage like the ECM, the catalytic converters and the DLC connector. The rest appear to fall under the regular 4/50 coverage. So unless I'm missing something, it looks like I'm out of luck unless it's the cat.
Which leaves me in a quandary about how to proceed... Get an $80 O2 sensor from eBay and try that first, or bring it to the dealer and hope it's the cat...
Old Oct 20, 2011 | 09:22 AM
calvin2376's Avatar
calvin2376
Wanted $800 for what, just one 02 sensor?
Well if you take it to a dealer you're out $120 immediately just for diagnostics if it's not the cat. Can you take it to a local/independent shop to get it checked out for less? If they tell you it's the cat, you can take it to the dealer and know you'll pay nothing. If it's the O2 sensor, then you know you can DIY.
I was under the impression, perhaps false, that the emissions warranty covered issues that would cause you to fail an emissions test, and I would assume with your car throwing an O2 failure-related code, you wouldn't pass emissions. Maybe I'm completely wrong here, I just thought I read that in the manual.
Old Oct 20, 2011 | 09:36 AM
Joe Z's Avatar
Joe Z
Might as well call your local Lexus dealer and ask if they will cover the O2 sesnor failuer under the Powertrain warranty.... It is part of the exhaust system & motor..
~ Joe Z
Old Oct 20, 2011 | 09:38 AM
Joe Z's Avatar
Joe Z
Lightbulb
Well yeah you were lucky...
If you break something in a snow storm or with road debris, that's really not considered a "part failure"..
~ Joe Z
Old Oct 20, 2011 | 09:49 AM
LDNN's Avatar
LDNN
Call the dealer and ask anyway, what have you got to lose, In fact call all dealers in your area, you my find one may agree to work with you.
Old Oct 20, 2011 | 10:18 AM
Bichon's Avatar
Bichon
There are two parts to the federal emissions warranty, a performance warranty and a design and defects warranty. The former one is what you are recalling, but unfortunately that one is only mandated by the feds to run 2/24 ( http://www.epa.gov/oms/consumer/warr95fs.txt ), and in the case of Lexus it's extended to the same 4/50 duration as the bumper-to-bumper coverage.
~ Joe Z
Unfortunately the powertrain warranty, which Calvin posted earlier in the thread, only covers a limited set of components that doesn't include the exhaust system.
I may do this - perhaps I can get them to cover it as a good-will gesture.
Old Oct 20, 2011 | 10:23 AM
kickin8's Avatar
kickin8
2IS/2RX/4RX
Call first...if they dont cover that...then get the O2 sensor for $80 would be your best bet
Old Oct 20, 2011 | 11:51 AM
Maxximus's Avatar
Maxximus
I wanna say the sensor was 400ish and then the rest was labor. I basically did the WTF rant to the guy and told him I was leaving. Got the usual, we're not responsible for anything that happens after you leave story. When the service manager came in the next day I called him up and told him the situation. They fixed it a few days later. This is also a deal gave my car to someone else "by mistake" when I went in for a recall, so who knows wth is going on over there.
Joe, I was literally stuck in a snow storm. Being in NJ, the counties don't like to plow roads until after 6am when they don't have to pay for OT to their road crews. There was probably 3" or more of snow on the highway, was also the last time I ended up driving in the snow with that car.
Old Oct 20, 2011 | 12:41 PM
Vroomin350's Avatar
Vroomin350
i know this is not my thread and I really dont mean to hijack but now that were on the subject (and to spare a new thread)
My CEL/VSC/TRAC control all lit up like a christmas tree the other day..
ran the scanner... cant remember the EXACT code but I remember it reading
something regarding the MAF and...
rich bank1
rich bank4
I apologize for the vague information I can try and scan it again tomorrow.. I hate to think its my intake.. this is the 3rd intake I go through
Old Oct 20, 2011 | 01:59 PM
Joe Z's Avatar
Joe Z
^^ Time to clean your MAF sensor..
With:
~ Joe Z
