Using the Bluetooth connection to play music?
First off, this is for an Android phone (htc hero). Instead of using the AUX port, is there a way to use the bluetooth connection from the phone to play music over my stereo in my 250?
^^^ Invest in a Blackberry Music Gateway. I have one for my car, it's $50 but it's so much nicer to not have to plug in every time you get in the car.
I only have one small complaint about the BMG. If your bluetooth is turned off on your phone when you turn on your car/BMG, it will not auto-pair with it, so you have to manually go into the settings and re-click on it (at least with my iPhone 4).
Other than that, it's great.
Not unless you have a 2010 or newer. Otherwise you have to use this method:
https://www.clublexus.com/forums/is-...sing-a2dp.html
