Old 01-09-15, 03:09 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Any link to changing engine air filter on a 07 IS250?
Old 07-19-11, 11:03 PM
98023IS250
98023IS250's Avatar
Default Any link to changing engine air filter on a 07 IS250?
I cannot find one and do not want to get in there and break something. I am a clutz and prone to breaking things I should not.
Thanks.
Old 07-20-11, 02:33 AM
UtoyZ
UtoyZ's Avatar
I think you meant cabin filter, here it is:
http://208.104.16.45/IS350/DIY_IS350CabinFilter.pdf
Old 07-20-11, 02:39 AM
KillaIS250
KillaIS250's Avatar
^ Actually, I think he meant engine air filter... at least that's what he's got in the title lol
Old 07-20-11, 02:41 AM
KillaIS250
KillaIS250's Avatar
BTW if you did mean the cabin air filter, DON'T FORGET: put the air on recirculate mode before you do anything!!!
Old 07-20-11, 04:01 AM
Bichon
Super Moderator
Bichon's Avatar
If I recall correctly, the instructions on changing the engine air filter are in the owners manual. Even if they aren't, changing the filter is extremely easy. You just need to remove the engine cover over it, unclip the clasps holding the airbox shut, lift the cover up enough to slip the old filter out and the new filter in, and then clip the box closed.
Old 07-20-11, 05:38 AM
UtoyZ
UtoyZ's Avatar
^ that's why i thought he meant cabin filter LoL
Old 07-20-11, 07:58 AM
98023IS250
98023IS250's Avatar
what the title said. Engine air filter. Not the cabin. I will have a look to see if I can figure it out tonight.
Old 07-20-11, 11:26 AM
Gville350
Gville350's Avatar
Steps I used in replacing the dirty OEM filter for a drop-in K&N :
*Use screwdriver tip to push center of plastic clips, remove clips from the pass. side cover and the three or four from the front cover on the airbox side.
*Remove the pass. side cover
*Unlatch the 4 or 5 latches holding the upper portion of the airbox to the lower...this can be done by hand.
*While lightly prying up on the front cover, pry up the upper portion enough to remove the filter. You should be able to slide it out without removing the upper airbox portion altogether.
*Slide in new filter (Note : there is an UP and DOWN portion of the filter!)
GL!
Old 03-03-13, 09:46 AM
connan23
connan23's Avatar
what is airbox?
bryceis250
Maintenance
01-13-18 11:31 AM
tommy152
RX - 3rd Gen (2010-2015)
05-08-16 11:14 AM
shikbas
04-01-16 09:53 PM
tukai
12-09-11 09:12 AM
rjacket
01-31-10 11:27 AM
Quick Reply: Any link to changing engine air filter on a 07 IS250?
