SC300 VVT-i Turbo SP63
Old Aug 16, 2003 | 06:23 AM
  #106
boredguy77's Avatar
boredguy77
A couple of things.
1.) I don`t know if you already stated this, but what standalone are you running.
2.) About the cupholder gauge, I had my boost gauge in there, and it was really a pain, it was almost impossible to look at it and drive at the same time. I can almost promise you that you will not like it other than the fact that you can hide it. You also lost your only reliable cupholder which kind of sucks. ok I am done analyzing now
3.) On the subject of TT headgaskets, is there a reason you are using two? If you search, theoretical calcs have shown that one TT h/g takes you to a good comp ratio, while two makes you a real low compression slug.
4.) On a side note the manifold is beautiflul, absolutely clean.
Old Aug 16, 2003 | 08:14 AM
  #107
TurboSC's Avatar
TurboSC
Originally posted by aliga
My jaws are touching the ground.
you have more then one jaw?
Looking great LL I can't wait for this beast to be on the street. I wish I had the cashflow to finish my car all in one sitting.
Congrats on having one the the coolest SC's EVER. mad props bro..
Old Aug 16, 2003 | 09:35 AM
  #108
SC300T's Avatar
SC300T
I agree with boredguy about the gauge... Mine is in front of the shifter, and its still next to impossible to see the boost, especially when you're trying to just keep the car straight and out of the rev-limiter.
Man what an impressive list of parts.... Did you take out a second mortgage or pimp yourself out on the corner for a month, you must be sore...
Old Aug 16, 2003 | 09:59 AM
  #109
boredguy77's Avatar
boredguy77
ROFLMAO
Old Aug 16, 2003 | 10:23 AM
  #110
SC300T's Avatar
SC300T
This is what Jon should do for his gauges:
Old Aug 16, 2003 | 10:24 AM
  #111
Richie's Avatar
Richie
Awesome update!!!
Will you be installing everything all at once?
Old Aug 16, 2003 | 10:57 AM
  #112
Ebanks's Avatar
Ebanks
No doubt you will be very happy with the 63 setup... That was to original setup on my car and I loved it.
Congrats.
-Ethan
Old Aug 16, 2003 | 11:47 AM
  #113
Lex Luthor's Avatar
Lex Luthor
Thx guys for your support.
5speed300 - looking to make over 500 rwhp, can't really get more specific yet, and cutting corners isn't in my nature, takes me forever to get things done.
aliga - thx Gazi, see you 'round the hood
octane and papa - thx, I was trying to attack every aspect, hope it lives up to your expectations
boredguy - 1) Autronic, same programmer as Motec, lots of great options and it interpolates a target A/F ratio for you if you use a Bosch WB O2 and their Autronic analyzer, ignition will be a DIS4 unit.
2) Didn't mind losing the cupholder since I don't really bring food/bev into the whip too much, I didn't expect that mounting location to be good ergonomically, I was a little more concerned w/ stealth, but to be honest that boost meter got slightly damaged on the bezel, so i'd like to replace it with a peak hold and warn unit, and that would negate the need to have your eyes on it all the time. I believe the EVC II may have an overboost warning as well, i'll check it out. Scott, if I was to cut the dash to 'glass in a pod for meters (and that does look like a perfect locale that you drew), I would rather put a nice ctr chan install there , worse comes to worse I can block off one center vent and build something there, i'll want a WB and EGT @ some point too, but I really don't want it to like like every damn ricemobile around here with a monster tach atop the dash and all that, just want to be able to quietly disgrace a worked M5.
3) Not sure what you consider a low compression slug , but Lar's calculations show two stacked TT gaskets to work out to 8.6:1, which is actually a tenth of a point above a stock TT's CR, basically exactly what i'm looking for. This is what Toyomoto does and sells as a Toyomoto head gasket. Even if it did work out to be a little lower, i'd rather have a safety margin since I intend to do a few dyno and track runs @ 19+ pounds, the MKIV guys are running as much as 22+ lbs, but they have the benefit of oil squirters for the pistons, believe me I try to work every little detail out before I commit to something. Lastly, the VVT-i will help VE which will help to build steam quicker (see a couple pages back), since the top two NA-T tuners in the country told me it will work i'll defer to their judgement.
4) word
Scott - Not sure how I did it, but I had been putting the money aside for the car and mods for awhile, and swore to myself I wouldn't make a single compromise, but now that i'm also planning a wedding that's already over the $50k mark, I definitely went a little crazy, better break out the fishnet stockings...
Richie - Yeah, whatever's not already in the car will be going in all @ once (other than the body kit), trying to get into the motor within the next few weeks.
Eth - Yeah bro, when you ran that 11.0 awhile back with the trans not wanting to 1-2 shift, i'd been watching the '63 since then.
Old Aug 16, 2003 | 12:26 PM
  #114
boredguy77's Avatar
boredguy77
everyone else gets a sentence, and I get a paragraph
I guess that is a good motto to live with, unlike scott and I who try to make the most out of our 10:1
have you considered methanol yet? I believe this is my next step. Anyways looking good bro, seems like you have thought enough about it and planned ahead, can`t wait to see the product.
Old Aug 16, 2003 | 12:38 PM
  #115
racing fan's Avatar
racing fan
Hmmm...Some other people had figured the single stock supra 1.3mm hg worked the compression to 8.8.. and a 3mm would be close to 8:1. Definetly do a compression check so we can compare numbers
Do you have the ecu pinout for the vvti engine? I'm interested in seeing if its the same as the older years and more importantly if it will accept the aem
good luck!
Old Aug 17, 2003 | 03:07 PM
  #116
NRG's Avatar
NRG
everything is great. but i never like RF amps
the only kit i would get on my sc, would be the one you got.. damn you im jealous heh
About the gauges, i would've got the Defi gauges. Because they would match the cluster perfectly.
i would also mount them on the edge of the clust/dash area.. blah, too hard to explain.
good luck.
Old Aug 17, 2003 | 04:46 PM
  #117
TurboSC's Avatar
TurboSC
Is that a photoshop or a real dash? That is sweet... and very tempting.
Old Aug 17, 2003 | 05:39 PM
  #118
5speed300's Avatar
5speed300
Im pretty sure its a photoshop. It looks like the skyline GTR dash
Old Aug 17, 2003 | 08:12 PM
  #119
TGRich's Avatar
TGRich
Looking good already boostbiscuit (loks like you might live up to that name afterall, eh? )
Anyway, keep us updated. I love your writeups with the attention to detail and how you explain everything.
When did the sc go distributorless?
Tim
Old Aug 18, 2003 | 01:54 PM
  #120
5speed300's Avatar
5speed300
Im also wondering about the missing distributor. I really think it makes the engine bay look horrible especially when its hiding a turbo.
