Lowered on nf210's w/tt wheels now I need a spacer?
Old Jul 2, 2011 | 10:30 PM
xspsi6's Avatar
xspsi6
Default Lowered on nf210's w/tt wheels now I need a spacer?
Drop looks good but it makes the offset look wrong and the 275's look small so any recomendations on spacers?
Thanks!
Old Jul 2, 2011 | 10:43 PM
SChema's Avatar
SChema
Wheel specs?
Old Jul 2, 2011 | 10:49 PM
xspsi6's Avatar
xspsi6
stock tt wheels, I am not 100% sure of the specs 8.5 front 9.5 rear 17in and can't remember the offset.
Old Jul 3, 2011 | 01:11 AM
Spooled's Avatar
Spooled
I just went with the H&R 20mm spacer kit. You will need to run extended studs with that kit, unless you want to go the KICS route, where it has bolt-on spacers. But they are not hub-centric like the H&R.
Old Jul 3, 2011 | 08:34 AM
xspsi6's Avatar
xspsi6
You were on stock tt wheels with this set up? Although I have never used a spacer before hubcentric is a must so where would I look for this kit? Is this just rear or both front and rear?
Old Jul 4, 2011 | 09:18 PM
Spooled's Avatar
Spooled
LuxuryMods.com has them. Fast shipping too. They sell them as a pair.
Old Jul 4, 2011 | 09:24 PM
xspsi6's Avatar
xspsi6
20mm all around?
Old Jul 5, 2011 | 08:40 PM
Spooled's Avatar
Spooled
20mm on the rears, but thats for my wheels. You need to look at the way your car sits with the wheels you have. get directly behind it and look, also look how far inset the very top of the wheel is from the fender and either measure or make an educated guess.
Old Jul 5, 2011 | 10:23 PM
xspsi6's Avatar
xspsi6
Oh I thought you were on TT wheels as well.
xspsi6
Sep 19, 2011 09:20 PM
cavette
Apr 20, 2010 09:16 PM
soaringsc3
Sep 18, 2008 08:04 AM
DJ420a
Aug 30, 2008 01:12 PM
RikTT
Jul 25, 2007 05:50 AM
