SC- 1st Gen (1992-2000)
1992 - SC400 - Fuel Pump Location
Old 06-17-11, 12:19 PM
jomidan
jomidan's Avatar
Default 1992 - SC400 - Fuel Pump Location
Sorry guys, but my eye ***** hurt from reading all the posts, but I can not find one post telling exactly where the fuel pump is at.
YOUR HELP WILL BE GREATLY APPRECIATED.
Thanks,
Old 06-17-11, 12:25 PM
turbodremz
turbodremz's Avatar
Behind the upper(back section) part of the rear seat. Remove the seats and you will see a round cover, remove that and the rest is easy.
Old 06-17-11, 12:30 PM
jomidan
jomidan's Avatar
Thanks !!!!!!!!!!
Old 06-17-11, 12:52 PM
1jzchris
1jzchris's Avatar
^^^^^^^^^^^ good job
Old 06-17-11, 01:53 PM
Teal Sc400
Teal Sc400's Avatar
DIY...http://www.postimage.org/image.php?v=gxlKV89
https://www.clublexus.com/forums/per...tures-faq.html
Old 06-17-11, 05:34 PM
jpw
jpw's Avatar
So just the fuel pump remove the front cover of the trunk , no seat removal needed
Ayotriple (03-24-20)
Old 06-17-11, 06:40 PM
turbodremz
turbodremz's Avatar
I take it you missed my post....
Step one: Remove seats. Lower section simply pops out. Back section has 3-12mm bolts (IIRC they are 12..), remove bolts, push seat in an upward direction to unseat tabs, pull forward and out.
Step Two: Look for the fuel pump cover that covers the cover...., not sure how to explain that right, but you will see it.
Step Three: remove fuel pump and do what is needed and enjoy the fumes on a hot day while sweating in the back of your SC
Old 06-18-11, 08:42 AM
jpw
jpw's Avatar
Ok i guess i am wrong ... Just saying i had clear view and access to it when i removed the front trunk trim when replacing my trunk struts last month but i guess u have to also remove the center seat section to remove...thanks sorry to mislead.
Old 06-18-11, 09:45 AM
turbodremz
turbodremz's Avatar
You can see the tank from the trunk yes, but the fuel pump can only be accessed through the back seat.
Old 06-18-11, 03:41 PM
jpw
jpw's Avatar
Thanks will remember that.
Old 06-20-11, 10:45 AM
jomidan
jomidan's Avatar
What you see from the trunk is the fuel gauge system, I thought the same until I removed it and saw the fuel pump all the way across the other side of the tank. The job itself was easy to do..Thanks for the information.
Jomidan
Old 06-20-11, 11:18 AM
MKIVS374
MKIVS374's Avatar
jomidan is right there is 2 access points from the trunk one is fuel gauge the other air vent. The pump is a larger hole behind the back seat.
coach1255
09-09-17 06:30 PM
eddieho68
10-31-15 05:30 PM
dicer
06-22-15 05:55 AM
iridebmx
15
07-24-10 01:17 PM
clean
Performance & Maintenance
06-07-07 04:59 PM
Quick Reply: 1992 - SC400 - Fuel Pump Location
