Headlight bulb/ls 400 ('98)
it's an HID bulb #20002. I've contacted a bulb supplier and they need more
info...is it a D1S, D1R, D2R...seems these are different bulbs. Dealer's aftermarket bulb is quite expensive and then there's the labor charge for approx $300. Would appreciate if someone has the info to please forward.
I just can't afford to replace at dealer's charge. Thanks so much. Ileana
it's an HID bulb #20002 for LS 400. I've contacted a bulb supplier and they need more info...is it a D1S, D1R, D2R...seems these are different bulbs. Dealer's aftermarket bulb is quite expensive and then there's the labor charge for approx $300. Would appreciate if someone has the info to please forward.
http://www.sylvania.com/ConsumerProd...lacementGuide/
looks like
1998 LEXUS LS400 (With HID (high intensity discharge) headlamps)
Low beam headlamp HID-D2R
High beam headlamp 9005
Our CL vendors carry them, or you can find them on ebay.
https://www.clublexus.com/forums/clu...ht-trends.html
https://www.clublexus.com/forums/clu...-save-big.html
https://www.clublexus.com/forums/clu...m-members.html
If you're going with an aftermarket bulkb the color / temp you'll want to be same as OEM is 4300k. 5000k is close to that and doesn't look too blue or purple
From experience with my 1998 LS400, the other bulb is probably not far behind the first one. Go ahead and get a pair of bulbs and replace them both now if you plan to keep the car for a while.
Dave has you covered.
Replace in pairs.
This CL Vendor:
A vendor outside of Club Lexus.
http://www.v-leds.com/Exterior-HID-H...-p8245149.html
Amazon with Sylvania bulbs:
http://www.amazon.com/Sylvania-66250...uct/B00265A5E8
All cars that come with a factory equipped HID system use 4100k-4300k bulbs. If you want a stock look I would recommend the Philips 4300k D2R bulbs
If you want something with a little but more color there is also 5000k, 6500k and 8000k. Keep in mind that the higher you go in Kelvin (K) the more color but the less usable light.
I would personally recommend 4300k if you want to maintain the stock HID look and to get the most light output. 5000k is also nice and will give you more of a crisp white color with a very slight hint of blue.
Here are some pictures from one of our customers that installed our 5000k bulbs -
I would also like to know if I should have the dealer change the bulb or
can anyone do this...are there instructions available?
I'm trying to limit the expense and my tire company says they can replace but I'm wondering?
Thanks again, Ileana
Steve
