SC- 1st Gen (1992-2000)
ABS problem after LS400 bbk install
Old 06-01-11, 11:32 AM
xspsi6
xspsi6's Avatar
Default ABS problem after LS400 bbk install
So it seems as if my ABS motor is engaging when I hit the brakes as the car slows down to a stop and this only happens at a certain speed it seems like like around 20- 5mph so I am at a loss as everything is new and I have checked everything over time and time again
Suggestions??
Old 06-01-11, 11:45 AM
socal72
socal72's Avatar
Dont think I have ever heard of anyone experiencing any problems like this but i'll keep my eyes and ears open for you and if I come across anything i'll let you know.
Old 06-01-11, 01:00 PM
xspsi6
xspsi6's Avatar
Yup it's a very odd problem to have and nothing is out of the ordinary including the ABS sensors on the hub.
Old 06-03-11, 04:49 AM
onejapman
onejapman's Avatar
i did the ls400 conversion on my car never had problems, u sure u tightened the brake lines?
Old 06-03-11, 10:48 AM
1FastSc
1FastSc's Avatar
check brake fluid
Old 06-03-11, 11:24 AM
BartleDoo
BartleDoo's Avatar
My ABS just flat out doesn't work.
Old 06-03-11, 10:32 PM
xspsi6
xspsi6's Avatar
Originally Posted by 1FastSc
check brake fluid
Yup brake fluid is still there The problem is way beyond fluid and bolts that are not tight...
Old 06-04-11, 06:04 AM
lexforlife
lexforlife's Avatar
sometimes air pockets get into the abs solenoid (when you open lines to change calipers) sometimes bad enough to engage abs prematurely.. try driving and stomping on the brakes ( in a safe area and not very high rate of speed) to fully engage abs to induce wheel lockup .. do it a few times then go back home and bleed system starting at rear passenger wheel to rear drivers the front pass then driver front but do it when engine running for that causes the abs unit to cycle
Old 06-04-11, 10:33 AM
xspsi6
xspsi6's Avatar
I did sort of do that as I went in some wet grass by my house to do this but I will try it a couple more times as soon as I order some more ATE super blue fluid, Thanks!
Old 07-20-11, 03:51 PM
FUZION
FUZION's Avatar
i have this problem now!!!1...did you fix your issue?
Old 07-20-11, 04:02 PM
xspsi6
xspsi6's Avatar
Nope not yet and I have bled 2 quarts of fluid through it but I am going to pull it on the hoist next month when I do my t-belt and find the root cause of this problem.
Old 07-20-11, 07:01 PM
FUZION
FUZION's Avatar
Please keep me updated on the issue. I was told that it could be the brake modulator.
Old 07-20-11, 07:22 PM
xspsi6
xspsi6's Avatar
I should state that Lexforlife was on to something as when I flushed it it got way better however flushing 25.00 per quart of ate super blue fluid gets costly so I almost think if I flush it 1 more time it will get better yet so try that and report back.
Old 07-25-11, 05:38 AM
FUZION
FUZION's Avatar
will do. flushing as in bleeding the system or flushing as in drain it and re-fill?
Old 07-25-11, 08:03 AM
xspsi6
xspsi6's Avatar
Bleeding.
Quick Reply: ABS problem after LS400 bbk install
