BAD Rear Suspension SQUEAK!
Old 09-15-10, 07:26 AM
Vosier
Vosier's Avatar
Default BAD Rear Suspension SQUEAK!
I recently installed a set of coil overs on my car. It rides nice but I've recently been hearing an annoying squeaking sound coming from the rear end. Everytime I hit a bump it makes the noise. Pushing down on the trunk and letting it go makes the sound. It's put out of commission until I have it fixed. I've heard that it's the control arm bushings. Is this the upper or lower control arm? Any thoughts of what to do? Your help is much appreciated guys. Thanks
Old 09-15-10, 07:38 AM
Infamous 1
Infamous 1's Avatar
Could also be the rubber mounts on the strut mounts. Maybe the springs isn't seated properly.
Old 09-15-10, 07:39 AM
Anthony
Anthony's Avatar
Bushings, lube them and your good. Had the same thing with my megans when I got them and now....not a peep
Old 09-15-10, 09:29 AM
GS4_Fiend
GS4_Fiend's Avatar
You lube the one at the bottom of the strut mount for ur megans?
Old 09-15-10, 10:08 AM
Vosier
Vosier's Avatar
Thanks guys. The problems is that I had the same noise even before I installed the coilovers. It progressively got louder since the car's riding much lower.
Old 09-15-10, 05:03 PM
Anthony
Anthony's Avatar
i just lubed everything while i had them out..so im not too sure which bushing but id say do all of them if you can
Old 09-16-10, 03:21 AM
airestonia
airestonia's Avatar
What do you use to lube your bushings?
I have a very similar squeaking problem up front that I cant' get rid of.
Old 09-16-10, 09:59 AM
GS4_Fiend
GS4_Fiend's Avatar
My right rear is squeaking i need to find out which one but i think most likely from the LCA from the rears.
Old 09-16-10, 09:42 PM
Vosier
Vosier's Avatar
Same it's mainly coming from the right rear. It's soooo loud and annoying! I lined every bushing possible...it's driving me nuts!
Old 09-17-10, 08:23 PM
looney
looney's Avatar
im on the same boat as you guys any results?
Old 09-19-10, 09:40 AM
Vosier
Vosier's Avatar
Just saw your post. EXACT SAME NOISE!
Old 01-04-11, 08:05 PM
jiggz808
jiggz808's Avatar
any updates on this problem?
Old 02-28-11, 02:18 PM
Mr Soarer
Mr Soarer's Avatar
I have the same problem just started last week... going to but the car on the lift and lube all the arm bushings on the right side...
Old 02-28-11, 03:50 PM
GS4_Fiend
GS4_Fiend's Avatar
Yep. I got it too and it's coming from the right rear. I bet it's coming from the LCA bushing.
Old 02-28-11, 05:35 PM
GS400world
GS400world's Avatar
Default Lca
Lower control arms!!!!!! Sure bet
Quick Reply: BAD Rear Suspension SQUEAK!
