rattle from muffler/catalytic converter?
Old 02-02-11, 02:05 AM
radiokilla
radiokilla's Avatar
Default rattle from muffler/catalytic converter?
I'm not super familiar with the exhaust layout on the LS. But when I start mine up there is a rattling noise (almost sounds like the car is scraping) its emanating from the center exhaust component. It comes after the headers and before the secondary mufflers. Basically dead center in the exhaust chain. What Im trying to figure out is. Is it a catalytic converter or just the resonator? I plan on redoing my exhaust soon But i was wondering if I need it for smog or not if it's a cat.
Thanks
Old 02-02-11, 07:55 AM
BunthaKev
BunthaKev's Avatar
You definately need a cat for smog test. the rattle is either a heat sheild above your cat or th heat sheild on your cat. get under your car and with a glove or rag so you don't burn your hand. press on the suspect with the car running. If it stops then there it is. If it doesnt, then shut off the car and bang on your cat. do you hear a rattle?
Old 02-02-11, 08:06 AM
radiokilla
radiokilla's Avatar
Yup that's exactly whatS rattling not the shield. Do I need a new cat? It Passed smog in the current state that it's In.
Old 02-02-11, 09:07 AM
radiokilla
radiokilla's Avatar
its like this in the photo. if you start from the tips and go away from the light source. its the last muffler-like part. Ive seen people just put x pipes here so i was wondering if thats the cat or resonator.
Old 02-02-11, 10:03 AM
JBrady
JBrady's Avatar
California cars came with center cats on the early 90-94 cars. There are many non-CA cars in CA so location is not the issue it is the original market that the vehicle was certified for. The catalyst has an offset inlet and outlet. The picture you posted is AFAIK a resonator. If yours looks like the one in the pic you posted you should have a resonator.
Either way you will also have 2 catalysts bolted one to each manifold near the engine with 3 bolt flanges. I am NOT certain if CARB testing checks original vehicle market data and then checks if there is a 3rd catalyst or not. You are PROBABLY safe replacing a 3rd cat with a straight pipe or resonator or X or Y pipe. You may want to do some searching on the law.
Here is a pic of an early LS400 Y pipe that you can just see the front of the 3rd cat and make out the offset inlet. The cat is diamond shape on the left of the pic with the passenger side manifold catalyst to the right of the pic.
Attached Thumbnails rattle from muffler/catalytic converter?-ls400-1st-g-calif-y-pipe.jpg
Old 02-04-11, 07:20 AM
BunthaKev
BunthaKev's Avatar
You wont need a new cat if it still works but to stop the rattle I've seen people use large hose clamps to tighten the sheilds to the cat. It's not pretty but will stop the rattle. Also a cheap fix.
Old 02-20-11, 02:30 AM
radiokilla
radiokilla's Avatar
Thanks everybody! I think i'm going to let it just chill because it still works. if its not broken no point in fixing it right? Plus ill be getting new mufflers soon which should cover up the rattle
Measured
04-19-18 09:58 PM
SynicalVip
01-27-13 12:26 AM
roodiggy
Performance & Maintenance
08-27-05 12:23 PM
MikeSC400
06-23-04 04:29 AM
SLVRGS
GS - 1st Gen (1993-1997)
10-23-02 01:06 PM
Quick Reply: rattle from muffler/catalytic converter?
