Tpms Light Will Not Turn Off After Air is Refilled
So a week ago I saw that my tpms light was flashing, i refilled all my tires with the recommended psi (35 front 38 rear for my AWD), now the light still flashes and will not go away. I have tried searching with no luck, does anyone know how to turn it off?
well since you refilled the tires back to the recommended psi, the light should go away after a few minutes. also, is the light flashing and then becomes solid, or just flashing?
I had a similar problem with mine. I pumped it up, and the TPMS wouldn't turn off. Being lazy, I left it that way, yet it never ended up turning off. It ended up being on for a good few months.
I actually finally got it to turn off by re-initializing the system today. It's in the manual. You make sure the tires are pumped up according to what you want to initialize it at. Turn on the engine, and press the arrows until the screen INITIAL PRESSURE or something shows, then you press the ON/OFF button and hold it for a few seconds. Not sure if it's going to mess up with TPMS system, but it worked in turning off the warning light.
Tech Info Resource
The spare doesn't have any impact on the TPMS. There is no sensor in it.
