SC- 1st Gen (1992-2000)
22''staggered rims on 95 sc 400
Old 08-15-10, 07:39 AM
sadwafair3
sadwafair3's Avatar
Default 22''staggered rims on 95 sc 400
i just purchased a pair of 22x10.5 rear and 22x9.0 front black giovanna libson wheels for my 1995 sc 400 with a offset of positive 35 front and 40 for the rear.my question is who out there has this wheel combination?i don't want my car raised nor cut in any way.my tire size is 235/30/22 front and 255/30/22 rear.
Old 08-15-10, 07:59 AM
fonzo
fonzo's Avatar
i think you would have to do everything you don't want. the wheel size will raise your car and you will need to get rid of your fender liners(no big deal). not sure what else you need to do. be sure to post up when you finish.
Old 08-15-10, 08:30 AM
sadwafair3
sadwafair3's Avatar
Old 08-15-10, 08:40 AM
Klaus
Klaus's Avatar
Those seem like truck tire sizes for that size of rim- I have seen 22s pulled off on a g35 coupe- had to run 20 on the profile- they were pure rubber bands. In order for this to look right you're going to need super stiff suspension to prevent rubbing and you're going to have to lower it and have a low body kit. The good thing is you didn't get ridiculous offsets so you should be able to have the wheel sit flush without running negative camber which will improve the overall height of the wheel/tire.
Most important thing here- 20s do not look good on a stock body 92-96 SC. Looks good on a 97+. But 22s will look like a donk without a body kit.
Also a quick google image search returned this:
See how rubber band those tires are? Still looks donk without a kit
Pics of the G by intense power:
turbodremz
turbodremz's Avatar
Unless you can pull off some serious camber, with those offsets/width and tire sizes, your going to have to roll/cut your fenders...but can I ask, why 22's? It just looks horrible...
http://www.youtube.com/watch?v=yD1g4...next=1&index=6
and did you really need 2 identical threads?
Old 08-15-10, 10:13 AM
xxtoobsxx
xxtoobsxx's Avatar
It has been covered, search 22"...anyway to save you some time it can look good if you do it right and if they are big chrome wheels.
https://www.clublexus.com/forums/sc-...d-setup-2.html
Old 08-15-10, 12:36 PM
pmpdaddyt
pmpdaddyt's Avatar
good lord thats huge!!!!! 20's look big on this car
Old 08-15-10, 12:39 PM
JDMmuscle
JDMmuscle's Avatar
Woooo this is already a fail in the making. Good lucking fitting these... you will have to tub the front and chop up all kinds of fender wells to make thise work without rasing your car.
you probably spent more on your wheels then your car
Old 08-15-10, 01:07 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
And i thought twentys were big. Post some pictures of them. Would like a look see of the end results.
Old 08-15-10, 01:33 PM
ScottURnot
ScottURnot's Avatar
Location: Sideways on the Yellow Brick Road! < Thats KS!
Guys! 20's arnt big! OK they can look big.
22's? Dont think they will look too great but you are here and welcome to prove me wrong. I run 20's on mine, that would be the max imo.
Just merged the 2 threads together.
Old 08-15-10, 01:44 PM
LEXXIUM
LEXXIUM's Avatar
You going to need to roll your fenders may be a cut too or you might have to go with hijacker suspension, that's if they even make it for our cars
Old 08-15-10, 03:16 PM
BartleDoo
BartleDoo's Avatar
Old 08-15-10, 03:41 PM
MIGS
MIGS's Avatar
sky jacked monster truck status yo.
Old 08-15-10, 05:21 PM
megamax
megamax's Avatar
thats 2 big!!!!
Old 08-15-10, 06:16 PM
SChema
SChema's Avatar
That's a bit too big.
Quick Reply: 22''staggered rims on 95 sc 400
