Ticking / Grinding noise on start up
Old 01-31-10, 02:47 PM
I8ABMR
I8ABMR's Avatar
Default Ticking / Grinding noise on start up
I have had this intermittent ticking/ grinding noise on start up. It lasts for maybe a second or two and goes away. I was wondering if anyone has this issue and if there is a TSB for it. I know there was an issue with grinding on start up with the 3GS for some owners but what I am hearing doest last more than a second or two whereas the videos I have seen from other GS models is louder and longer. Maybe its the same issue but its just starting???. Not sure. I am taking her in tomorrow, but I am hoping they are not going to tell me the "can't reproduce the problem".
Old 01-31-10, 03:02 PM
spine911
spine911's Avatar
GS350 + engine clatter/grinding upon initial engine startup
...sounds like you have the dreaded startup cam gear problem,
TSB fix #EG020-07 - if this is really your problem.
goodluck
Old 01-31-10, 04:08 PM
Rider
Rider's Avatar
Sorry to go offtopic but does any know where can I find a list of all the TSB's released??
Old 01-31-10, 05:52 PM
I8ABMR
I8ABMR's Avatar
goodluck
I am taking her in tomorrow and I will mention the TSB . The noise is not consistent but it seemed louder today than the previous 3 times I have heard it. The odd thing is that I usually only hear it when the car is cold but today I went to the store and it did it when I got back into the car after shopping. The car had only been off maybe 20-30 minutes. I hope they can get to the bottom of this for me
Old 01-31-10, 08:49 PM
THE.K.W.C
THE.K.W.C's Avatar
hey i had a grinding noise from a busted heater housing. the door that houses the interior air filter broken off and every time I started the car i would hear a loud grinding sound. You can tell if its the same problem by felling the passenger side under dash and if it shakes then there's your problem.... some what of a easy fix
Old 01-31-10, 09:12 PM
EyeKutr
EyeKutr's Avatar
i8, it sounds like the cam gear thing, mine was fixed and its been good since
Old 01-31-10, 10:12 PM
vuiskool
vuiskool's Avatar
Good luck on trying to replicate the sounds.
Old 02-01-10, 01:32 AM
I8ABMR
I8ABMR's Avatar
Thats what I am concerned about. My service rep is really good so I am hoping it will be taken care of
Old 02-01-10, 01:09 PM
lkapimp216
lkapimp216's Avatar
does anyone know if the 06 is affected by this issue and if so is there a tsb for it the only info i can find is on the 07
Old 02-01-10, 02:01 PM
EyeKutr
EyeKutr's Avatar
06 is affected also
Old 02-01-10, 02:22 PM
Lexus_Star
Lexus_Star's Avatar
I have this grinding noise also on my 07 350. I notice it occurs mostly on cold starts, and lasts maybe one second. Is there any additional info i can provide other than the TSB number when I call up the dealer?
Old 02-01-10, 02:45 PM
Mesca
Mesca's Avatar
I also have a grinding noise when I start up my car. Sort of sounds like something I heard from the Transformers movie. Anyone know if the TSIB applies to 08 GS350's?
Old 02-01-10, 04:26 PM
I8ABMR
I8ABMR's Avatar
I took the car in and my service rep they will fix it under the TSB. Its going to be there for another day or two. I am glad to get this fixed. I dont like the idea of engine issues
Old 02-01-10, 05:39 PM
spine911
spine911's Avatar
^IA8,
-is it the cam gear issue/TSB?
-(if it is the cam gear TSB), can you verify from the dealer is they will dismount the Cylinder head....based on the TSB part list it requires replacing the cylinder head gaskets
Old 02-01-10, 10:27 PM
I8ABMR
I8ABMR's Avatar
I have a lot of faith in the techs at Bell Lexus. They said they have already done one or two of these jobs already so it shouldnt be anything to difficult
Quick Reply: Ticking / Grinding noise on start up
