Which do I have, the U140E or the A541E transmission?
Old 07-10-10, 02:40 PM
Funkdoobiest
Funkdoobiest's Avatar
Default Which do I have, the U140E or the A541E transmission?
2000 ES300. How can I tell?
Old 07-11-10, 10:09 PM
Funkdoobiest
Really nobody knows? WIll it simply be stamped in a certain spot? On some kind of options sticker? When shopping for a used trans it shows these two different options. One is cheap, one is very expensive.
Old 07-12-10, 04:27 AM
mikejerez
mikejerez's Avatar
I believe my ES300 has it on the driver door sticker. Although mine says A140E. Weird
Old 07-12-10, 05:26 AM
Funkdoobiest
What's wrong with that? That's the cheaper one.
Old 07-12-10, 08:22 AM
MikeLex
MikeLex's Avatar
My 98 ES300 has A541E stamped on a small plate riveted to the firewall (driver's side upper corner)
Old 07-12-10, 06:27 PM
Funkdoobiest
I don't have the plate or even a door sticker. Hmmm. Any other way to tell? There were some numbers etched on the top of the trans, but it didn't even resemble the model #s.
Old 01-10-11, 04:30 PM
dboy1211
dboy1211's Avatar
Angry A541e//u140e
If it does not say on your driver side door, another way to tell is to actually go underneath the vehicle and count how many bolts are in the transmission pan. 18 bolts = U140E ,,, 17 bolts = A541E .
Be clear about this when ordering one, I did my research prior to ordering one, made sure I told them U140E, and they still shipped me the wrong one. It turned into a big hassle considering they supposedly record their conversations but lost mine. And shipping costs for a transmission can easily be $300 to $400.
Old 01-10-11, 04:52 PM
PFB
PFB's Avatar
If you call any Lexus dealer and give them your VIN number, they should be able to tell you over the phone. Your best bet is the parts department, not the service department.
I believe (but am not sure on that one), that the transmission that you have determines the type of transmission fluid that you MUST use. Either Dexron 3, or Toyota Type iV Transmission fluid. So its important to know what you got.
Phil
Old 01-10-11, 06:17 PM
Received 2,697 Likes on 2,283 Posts
You have the U140E, it was used on the 1999-2003 ES300.
Old 10-19-11, 02:17 PM
Zoonwen
Zoonwen's Avatar
Sorry to bring back an old thread, but is there a way to tell between A541E/A540E 's. No vin or chassis available to look up. Just have a few transmissions I cant figure out what they came from.
Old 10-19-11, 02:27 PM
DRACO A5OG
DRACO A5OG's Avatar
94-96 = A541E
I believe yours is A540E
Old 10-19-11, 03:13 PM
Zoonwen
Zoonwen's Avatar
Here is a pic of the gear selector.
Attached Thumbnails Which do I have, the U140E or the A541E transmission?-img_1237.jpg   Which do I have, the U140E or the A541E transmission?-img_1236.jpg
Old 10-19-11, 06:57 PM
DRACO A5OG
DRACO A5OG's Avatar
Nope that looks like mine off of the A541E. 93 to 94 trans are not compatible, ask me how I know.
Old 10-20-11, 09:48 AM
ASG14
ASG14's Avatar
The part # off that gear selector shows as 94+ (A541E)
Old 11-04-11, 03:36 PM
SmoothV63
SmoothV63's Avatar
Okay bringing it back again. Transmission type. I have a 94 es300 yet i was told it has a 95 motor. Now i ned to replace transmission and IM at a lost to what it is and what to look for to go with motor. Help a DIY. In need.
Quick Reply: Which do I have, the U140E or the A541E transmission?
