Draining Gas Tank on a 96 LS400?
Old 05-08-10, 08:30 PM
1996LS400
1996LS400's Avatar
Default Draining Gas Tank on a 96 LS400?
I'm trying to rule out the possibility of water/condensation in my tank as the car sat for close to a year with a pretty empty tank. It's really running rich blowing white smoke and giving random cylinder misfire codes. I put 10 gallons fresh fuel and some water absorber treatment with no luck yet. I plan on letting my 17 year old use it for school and work only because he's a damn good kid.
1996 LS400
Old 05-08-10, 08:32 PM
Och
Och's Avatar
Well, you can take off the fuel filter (look on lexls.com for tutorial) and turn the ignition on, but dont start the car. It will pump the fuel out.
Old 05-08-10, 09:01 PM
Thermactor
Thermactor's Avatar
your problem is not because of gas, you might have a had a coil die
Old 05-08-10, 09:02 PM
1996LS400
1996LS400's Avatar
That sounds like a hell of an idea with the fuel filter! I found the link, it says for 90-94 but I'm sure it will get me close enough. Thanks!!!
Old 05-08-10, 09:06 PM
1996LS400
1996LS400's Avatar
It's kind of weird. After I disconnected the batt and it was cold, I started it and no codes even after idling for a few but it still smoked and idled rough. After a min or two I took it around the block and the codes show up. First time it was cylinder misfire 2 & 4. Parked, waited about 10 mins drove around the block again, rescanned and it said cylinders 6 & 8. I tried it again yesterday and only got cylinder misfire on 2. Does this still sound like it could be a coil issue?
Old 05-09-10, 02:46 AM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
it doesnt sound like it has to do with the fuel itself, more likely clogged injectors or some sort of electronic ignition/ecu issue.
Old 05-09-10, 06:29 AM
Och
Och's Avatar
I'd start by draining the fuel, and then filling up 1/2 tank of high octane fuel, and adding a can of good fuel system cleaner, such as BG44K or Techron. Run it through the engine and see where that takes you. If that does not improve things, do a full tune up and check that the timing belt is aligned properly.
Also, to eliminate the possibility of a bad ignition coil, switch them places. If you're getting misfire codes on 2, 4, 6, 8, you will get them on 1, 3, 5, 7 after switching coils, if one of them is bad.
qewani1
02-23-15 01:53 PM
tyncobb
10-31-14 11:19 AM
nurvcom
09-27-11 02:25 PM
qewani1
04-14-09 03:09 PM
UofACATS
16
05-30-08 02:46 PM
Quick Reply: Draining Gas Tank on a 96 LS400?
