Well i hope im not going to have problems. Noticed a leak around my tranny pan (gasket). Gonna have to drop it to change the gasket. Dealer wants like 500 bucks to change gasket and fuilds.On top of that my rear bearing are going bad waiting on a qoute for that. Seams like im replacing alot of parts about now. I do the minor work on car. I cant complain there parts that eventually wear. 2002 ls430 123,xxx and climbing.
AFTER 80k miles? Whats the reasoning they gave you behind that one? I could understand them saying that it does not need to be done BEFORE.
For those that have changed their fluid, I read on another post that you can either drop the pan or the fluid lines. If you drop the pan you only get about 2quarts out, where you can get the majority of it by going through the line. What have you guys had done when you had your fluid changed. I don't think I want to pay for a partial fluid change.....
Originally Posted by Jabberwock
Don't know the origin but I have also heard this advice/story many times - not from trained mechanics just word of mouth mostly, for the last 30 years - "If you haven't changed Tranny fluid on a car ever and it has 80k or more its better to just leave old fluid because changing the fluid would cause clean out the old tranny and cause it to fail.
Yea that's about right, like the old fluid is keeping everything sealed and the new fluid will give it issues. Thats why you should do it like at least every 50k.
So its like 2-3 quarts to drop the pan and refill, but how about a complete flush? On my car its 11 something quarts 5at, so surly for 6speed AT will be up there.
I would go ahead and flush the trans even at greater than 80k. I am a big believer in running with clean oil/fluids in my cars. Take care of your car and it will take care of you is how I think about this.
You must TOW with your Lexus or powershift the tranny (lol)...right? If not, I think every 25k is pretty darn excessive!
25k is not excessive at all, actually is just about right for a perfectly maintain tranny.
I just replaced the tranny fluid in our GS300 at 23k miles, and the fluid is getting dark already. It is not pitch black yet, but is not clear anymore.
The main reason the WS fluid in our "sealed" tranny lasting longer is because it is a synthetic fluid. The older tranny that uses non-synthetic fluid require fluid replacement at 30k miles. So 25k is just a hair sooner, not excessive at all.
This is the reason why some car's tranny still shift perfectly smooth at 200k miles and some tranny is dying at 100k miles, regular fluid changes
GeorgeT's tranny is going to last a very long time. His dealer is good!
^ so changing at 73k should be no issue right? One guy at the lexus dealer was like yea you don't need to change it until 100k, then another guy said no it will start slipping.
Also no one seems to know the amount of fluid needed for the whole tranny. 12 quarts?
Performed Repair // Fill Amount
Radiator removal // 0.7 liters (0.74 US qts, 0.61 Imp. qts)
Transmission hose and pipe removal // 0.6 liters (0.63 US qts, 0.53 Imp. qts)
Output shaft oil seal replacement // 0.4 liters (0.42 US qts, 0.35 Imp. qts)
Transmission pan and drain plug removal // 1.3 liters (1.37 US qts, 1.14 Imp. qts)
Transmission valve body removal // 3.9 liters (4.12 US qts, 3.43 Imp. qts)
Torque converter replacement // 5.3 liters (5.60 US qts, 4.66 Imp. qts)
Entire transmission assembly // 7.2 liters (7.61 US qts, 6.34 Imp. qts)
HINT: If you cannot add the listed amount of fluid, do the following:
(1) Install the refill plug.
(2) Allow the engine to idle with air conditioning OFF.
(3) Move the shift lever through entire gear range to circulate fluid.
(4) Wait for 30 seconds with the engine idling.
(5) Stop the engine.
(6) Remove the refill plug and add fluid.
(7) Reinstall the refill plug.
