DIY / Info thread for LS460/LS460L/LS600hL
Old 10-09-09, 10:08 AM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
Default DIY / Info thread for LS460/LS460L/LS600hL
Here's a thread for all the DIY and useful information for the LS. Please feel free to add links to the thread with a little description what they are about. Please try not to discuss issues in this thread, please bring the discussion to the individual threads.
rominl is offline
FatherTo1 (01-01-17)
Old 10-09-09, 10:09 AM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
DIY to remove maintenance light / msg after oil change
https://www.clublexus.com/forums/ls4...ice-light.html
rominl is offline
Old 10-09-09, 10:27 AM
LexFather
Guest
Posts: n/a
Cool Official (Official) LS Links thread (Rollcall, DIY, Articles etc)
We are going to put important links in one thread instead of having 500 stickies in the LS forum, for a cleaner look. Big thanks to everyone who has contributed to those threads!
Modification Thread
https://www.clublexus.com/forums/ls4...on-thread.html
LS Youtube videos
https://www.clublexus.com/forums/ls4...be-videos.html
Rollcall Thread
https://www.clublexus.com/forums/ls4...ll-thread.html
600h L Review Thread
https://www.clublexus.com/forums/ls4...ws-inside.html
Awards Thread
https://www.clublexus.com/forums/ls4...ds-thread.html
460 Review Thread
https://www.clublexus.com/forums/ls4...ew-thread.html
Lexus Japan: LS L-Select
https://www.clublexus.com/forums/ls4...-l-select.html
Oil Change on a LS460/LS460L..
https://www.clublexus.com/forums/ls4...60-ls460l.html
4LS World Firsts
https://www.clublexus.com/forums/ls4...ld-firsts.html
LS Sport (there are other threads, this is the first one)
https://www.clublexus.com/forums/ls4...or-2010-a.html
Old 10-20-09, 08:35 AM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
Rattle fix on front side speaker grille / dash
https://www.clublexus.com/forums/ls4...ml#post4940750
rominl is offline
DavidinCT (10-24-17)
Old 11-25-09, 02:06 AM
Johnny
Johnny's Avatar
Post OBDII - LS460/600 Configuration
Hopefully we never have to use this tool, but having it at our disposal arms with data before we take the car in for service, or DIY. The tool itself is redundant if there is nothing wrong with the car. However, when the Check Engine light appears on your dash, it will readout the culprit code. If you subscribe to the manufacturer's complementary software, it will give you the industry standard amount of labor required to correct the fault and any other pertinent data. The other port adjacent to the OBDII is for Toyota's computer link.
OBDII - On-Board Diagnostics Type 2 '96 onward...
Driver's side under dash, left of brake pedal next to fuse box
Lexus Code Retrieval - Trouble Codes
Code Reader can be purchased from Costco for $90...
Johnny is offline
Old 01-16-10, 11:10 AM
Rash
hmm
Rash's Avatar
The modification thread links you to page 9.
Rash is offline
Old 02-13-10, 10:30 AM
LexFather
Guest
Posts: n/a
Thanks updated
Old 03-05-10, 07:02 AM
lexusnutt
lexusnutt's Avatar
There seems to be a lot of references to this website for ls460 TSIB's
Pretty complete listing. I may one day copy all of the files and post them to www.scribd.com for permanence.
http://www.lambros.net/2007LS460L/tsib/
lexusnutt is offline
Old 03-22-10, 11:58 AM
walking50
walking50's Avatar
hello ...
can anyone provide instructions on how to replace the HID bulbs on the LS 460 .... seems pretty cumbersome to get through to the bulb cover..
thanks
walking50 is offline
Old 04-23-10, 03:48 PM
Johnny
Johnny's Avatar
The following uses a Chamberlain (Sears Craftsman) rolling code opener; it may also apply to other RCOs as well. The Lexus and Chamberlain directions "separately" are ambiguous and self-serving, so these instructions merely marry the two:
There are two important sequences to follow in this procedure:
1. Pairing the car's Homelink system with the door opener's handheld remote, and...
2. Pairing the door opener with the car. It is important to perform both.
Before starting, set up a ladder to gain access to the "Learn" button on the garage door opener. No need to depress the button at this time. Also make sure the car does not obstruct the passage of the garage door, as it may be activated during this procedure. Keep children animals or other obstructions clear of the moving door's path. To avoid activating the door when pairing the handheld remote to the Homelink, pair the two a block away from your garage.
SEQUENCE I
1. No need to have engine running. Homelink is always active on Lexus cars.
2. Clear/reset the Lexus Homelink by depressing buttons 1 & 3 for 20 seconds.
3. Hold the Chamberlain remote within three inches from the LS Homelink keypad.
4. Depress and hold the desired Homelink button 1, 2 or 3. LED turns on steadily.
5. Depress and hold the Chamberlain remote keypad until the Homelink LED begins to flash rapidly. Release both.
SEQUENCE II
6. Exit car and access the door opener's "Learn" button. Briefly depress the "Learn" button until its LED turns on.
7. Within the allotted 30 second period, return to the car and depress the chosen keypad button briefly one time.
The opener's lights will flash confirming the pairing of the garage door opener, and the car's Homelink.
Test the operation the Homelink. You're done!
Johnny is offline
Old 05-03-10, 12:14 AM
Johnny
Johnny's Avatar
Default LS460 & LS600hL Oil Change Procedure
Oil Change Link
Johnny is offline
Old 06-07-10, 12:17 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
fantastic wind noise fix by jmcraney
https://www.clublexus.com/forums/ls4...ml#post5548737
rominl is offline
Old 06-18-10, 02:21 AM
kurtdaniel
kurtdaniel's Avatar
much thanks to this thread..very helpful for us LS460 owners..in return i would like to share this diy for Brake Pad Sensor..
kurtdaniel is offline
Old 10-28-10, 08:42 AM
CJITTY
CJITTY's Avatar
Default LS460 HID Fog Install DIY
Here is my post about installing HID fog lights on my LS460
https://www.clublexus.com/forums/ls4...for-ls460.html
CJITTY is offline
Old 01-05-11, 07:45 AM
KJFenton
KJFenton's Avatar
Default Place to find dealer info for repairs/TSB/service, etc...
This site will list ALL TSBs and detailed repair info that only your dealer sees. Even service procedures.
Go to www.ALLDATAdiy.com - the cost to sign up for a 5 year subscription is $46 / one year is like $23 - register your car and never be in the dark again.
KJFenton is offline
Quick Reply: DIY / Info thread for LS460/LS460L/LS600hL
