Wont Shift into Overdrive
Old 01-08-10, 11:22 AM
Dirty SC
Dirty SC's Avatar
Default Wont Shift into Overdrive
I have a 95 SC300 Automatic with about 170,000 miles i bought this car about 8 months ago
The problem started about a week ago. i noticed that while going about 50-55 mph my rpms stay at about 3000rpm when usually they would be below 2000. so the first thing i did was press the overdrive button the shifter and nothing the Overdrive light doesnt come on in the dash when it used to and it still doesnt go into overdrive. all of the other gears go in fine. no slipping no hard shifts, it downshifts smoothly.
next step i did was change the Fluid and filter in the tranny and still nothing.
the tempurature outside usually is around 80-90 degrees, but we had a cold front for the past week and outside tempuratures are around 35-50 degrees. i noticed while driving i see the tempurature gauge stay below the middle where it usually is. could it be that the person that had the car before me took off the thermostat? ive yet to check but it seems like the thermostat is either stuck open or there is no thermostat at all from just looking at the temp gauge..
i read on other forums that if the operating tempurature on the car is too low, the ECU wont let the transmission shift into overdrive so it wont put a load on the motor while it being under the operating tempurature. i dont know if this is true.
has anybody ever had this issue with there SC300s?
Could it be that my Transmission is on its way out?
I also hear it could be my ECU is going bad. i just dont know what to do.
Old 01-08-10, 12:36 PM
YeA 2jZ
YeA 2jZ's Avatar
could be a few things transmission shift point controled by three elements. Engine temp sensor located behind the water inlet from the rad. Also tps and ecu. it could also be a solenoid in the trans itself. The easiest thing to try is the ecu. If you can borrow a KNOWN working ecu it should solve ur problems if not give the other things a check
Old 01-08-10, 07:26 PM
RyanV
RyanV's Avatar
when you say ecu, you mean the main engine ecu right?
Old 01-08-10, 09:27 PM
R3DGS3
R3DGS3's Avatar
Yes main engine ECU controls transmission as well as climate control among other things
Old 01-08-10, 10:23 PM
DRFT103
DRFT103's Avatar
ECU for sure bro.
Old 01-11-10, 05:29 AM
Dirty SC
Dirty SC's Avatar
thanks for your help. i have been trying to find somebody locally with an ECU but i havent had any luck...i have a friend that has a 97 sc300 but i believe his is OBD II mine is OBD I and he said that his computer wont work on my car. is this true??
Is there Any SC300 owners in the West Palm Beach FL area that can let me use your ECU for a couple minutes i would greatly appreciate it.
Old 01-11-10, 06:22 AM
YeA 2jZ
YeA 2jZ's Avatar
I am not quite sure if the one from a 97 would work if its OBDII then for sure it wont work. I live in near pembroke pines i dunno if you would like to drive down a bit mabey i can help you out i have a 92 auto
Old 01-11-10, 08:16 AM
Dirty SC
Dirty SC's Avatar
thanks man if i cant find anybody localy, i will definatly be sending u a PM.
pembroke pines is that exit Hollywood? i think thats like about an hour away.
Old 01-11-10, 10:46 AM
YeA 2jZ
YeA 2jZ's Avatar
Yea thats the Hollywood ext if ur on I-95 but i am off the Miami Gardens Exit on I-75
Old 03-28-10, 06:34 PM
BrownGuy
BrownGuy's Avatar
Updates? Did the different ECU solve this issue?
(having a similar problem)
Old 03-28-10, 11:17 PM
Dirty SC
Dirty SC's Avatar
YES ECU fixed the problem! just got an ecu last friday! and sure enough as soon as a plugged it in my car ran smoother and overdrive went in no problem!
Old 02-23-11, 10:03 PM
bjoyce
bjoyce's Avatar
so when you're going 50-55mph what are the rev.s at?
Old 06-14-15, 06:18 PM
purvis73
purvis73's Avatar
Hey guys I need help my 95 sc300 won't shift into overdrive. Every gear is shifting fine no lights on dash,overdrive button is working, please help.
Old 08-26-15, 06:39 AM
rbrucek
rbrucek's Avatar
Default same peoblem
I have a 1995 sc300 that will not shift into overdrive. The only other thing is the track light comes on and stays on. Could that be the ecu or the senser on the trans axle.
FireCode
17
07-26-20 08:22 AM
nortreboss
SC- 1st Gen (1992-2000)
12
02-26-11 11:46 AM
jchrisf
Maintenance
03-30-07 05:19 AM
Vog
12-23-05 08:51 PM
Ag02M5
Performance
12-06-02 03:47 PM
Quick Reply: Wont Shift into Overdrive
