Change Rear Differential Fluid
Old 12-24-09, 05:25 PM
Poqman
Poqman's Avatar
Default Change Rear Differential Fluid
Dealer wants $120 to change the differential fluid. Is there something more to this than I think? Is it as simple as pulling a plug and either draining or sucking out the fluid? Is a flush required? Would you use OEM fluid or go to a synthetic? My RX330 has 47k miles. Thanks.
Old 12-24-09, 08:40 PM
Hayk
Hayk's Avatar
I heard it's just drain and fill. But I looked at the differential and you need a hex key to unscrew the bolts. I think you also have to replace the gaskets like with an oil change. I've never done it though.
Old 12-25-09, 08:58 AM
diverchris
diverchris's Avatar
I would go to a mechanic or a toyota dealer to have the fluid changed. I would recommend synthetic fluid over OEM
Just my two cents
Old 12-25-09, 09:54 AM
johncdoyle
johncdoyle's Avatar
I have done this twice on my '04 RX 330. I bought the gaskets at the dealer and had the hex socket driver needed. I used Mobil 1 Synthetic and also did the transfer case fluid at the same time. The transfer case check and drain plugs are much harder to reach than the diff. You can buy the fluid and the tools and have $90 + left for your trouble...plus you'll then know how to do it. If you change your own oil, this is much easier. Good luck!
Old 12-25-09, 09:58 AM
salimshah
Forum Moderator
salimshah's Avatar
Received 1,104 Likes on 993 Posts
There is a thread in First gen with photo. Check that out.
The reservoir contains the fluid. After draining you get almost all of the fluid out [unlike transmission where a good portion is left in the system]. If you want to clean it a bit more, pour about 1/2 qt through the inlet, while the drain plug is removed.
Sticking with OEM is safe but you can always switch to better fluid, but you must do the research. What the other lube shops have in their vats may be of lesser specs than OEM.
As a DIYer, make sure you can open the fill plug before you attempt the drain. You may need special tools and the plugs may be tight. For he first gen, the size of the head is standard, but the clearance requires specail tool. Let me caution you that the stuff smells nasty.
One does not need special training to do the job, so you can certainly go to other places. Just make sure you supply them the right fluid, and crush washers.
Salim
Old 12-25-09, 12:45 PM
Poqman
Poqman's Avatar
thanks salimshah for the tip. I found the first generation instructions and pictures great. It answered all my questions.
Old 01-02-10, 08:39 PM
badams1897
badams1897's Avatar
What is the OEM spec fluid? Anyone have a part number for the gaskets?
Old 08-06-10, 06:17 AM
badams1897
badams1897's Avatar
Hate to bump this but I cannot find it anywhere anyone know what type of Diff fluid the RX330 uses?
Old 08-06-10, 06:42 AM
veleno
veleno's Avatar
Owner's manual perhaps?
Old 08-06-10, 07:21 AM
ycl1688
ycl1688's Avatar
It is in the manual 80w-90 for transfer case and diff.
Old 08-06-10, 09:46 AM
Lexmex
Super Moderator
Senior Moderator
Lexmex's Avatar
You can use 75W90 synthetic. My oil of choice right now is the Royal Purple 75W90 MaxGear oil, but I'm always experimenting.
Old 08-06-10, 02:32 PM
badams1897
badams1897's Avatar
Bangs head on wall forgot about the owner's manual. Thanks for posting.
Old 05-03-11, 10:58 PM
stevengtt
stevengtt's Avatar
Hi guys,
I'm just wondering do i have a rear Diff in my 2003 2nd gen harrier? (JMD)
It is front wheel drive.
Steve
Old 05-04-11, 05:53 AM
thomas1
thomas1's Avatar
The AWD only has the differentials...FWD (front wheel drive) does not.
Old 05-04-11, 06:41 AM
lexus114
lexus114's Avatar
I replaced mine with Amsoil severe gear. The Royal Purple stuff is real good too.
Quick Reply: Change Rear Differential Fluid
